Warm Transmission Tunnel
xatz
Postby xatz » Sat Jan 17, 2009 10:37 am
How hot should the transmission tunnel get while just driving normally (maybe with a few squirts here and there :P ) ?
After driving for a little while the transmission tunnel gets quite hot to touch on the inside of the car, is this normal?
What do you think could be causing this?
JD
Fatty
Postby Fatty » Sat Jan 17, 2009 10:47 am
mine's very hot too touch as well. i guess it's just the heat coming off the exhaust , and gearbox.
Juffa
Postby Juffa » Sat Jan 17, 2009 10:50 am
Please give us some more details on your particular MX-5?
Based on what you have told us it sounds like one or both of rubber boots around the gear stick have broken. This is fairly common, especially in older cars.
Here is a link to the miata.net garage with replacement instructions;
http://www.miata.net/garage/shiftboot.html
Here is upper boot, it seals the gear shift hole in the car body and keep the heat and dust/dirt out.
Here is the lower boot, it keeps the dust/dirt out of the gearbox turret and if you have a NA (1989-1997) model, it also keeps the turret oil in.
J
xatz
Postby xatz » Sat Jan 17, 2009 11:14 am
Juffa wrote:Please give us some more details on your particular MX-5?
Ah, crap sorry man. My original draft had some info but must have been lost when when my browser decided to log me out.
I've got a 1989 NA that's pretty much stock. The gear stick itself isn't hot at all, just around the lower half of the centre console in the foot well up to the gear stick surround and a bit towards the ash tray area.
I'll pull the centre console out this afternoon and see what condition the gear boots are in.
JD
Juffa
Postby Juffa » Sat Jan 17, 2009 11:29 am
xatz wrote:The gear stick itself isn't hot at all, just around the lower half of the centre console in the foot well up to the gear stick surround and a bit towards the ash tray area.
A broken upper boot will do that.
J
Fatty
Postby Fatty » Sat Jan 17, 2009 12:26 pm
my upper (and lower) boot is only a few months old and my tunnel still gets very hot.
xatz
Postby xatz » Sat Jan 17, 2009 2:37 pm
Juffa wrote:A broken upper boot will do that.
How about a nearly non-existent upper boot :shock: Image
Fatty wrote:my upper (and lower) boot is only a few months old and my tunnel still gets very hot.
That's good to know if new ones don't solve it for me. Where did you get your boots from?
JD
philz
Wheel guru
Postby philz » Sat Jan 17, 2009 2:46 pm
xatz
Postby xatz » Sat Jan 17, 2009 2:58 pm
philz wrote:http://www.mx5plus.com.au
Thanks Philz :D That's another mx5something.com.au to add to the list :P
And thanks Juffa and Fatty for your help. When I get new boots I'll let you know if the heat goes down.
JD
Hellmun
Postby Hellmun » Sat Jan 17, 2009 7:53 pm
Those seals will stop the air coming up into the cabin but the tunnel itself will still get quite hot. Especially on the freeway.... I had no carpet and the centre console removed once and the metal itself gets baking hot.
Postby sliq » Sat Jan 17, 2009 8:45 pm
try better insulation also. just get the ladder, go up to the man hole in ur house, and get some from there. jks.
bensale
Postby bensale » Sat Jan 17, 2009 10:06 pm
Wow! They're well and truely gone! You'll be very pleased with the difference the new boots will make, I was very much so.
www.othersideproductions.com
dingmaz
Postby dingmaz » Sun Jan 18, 2009 6:03 am
They were the first things I checked and replaced, made a huge difference to heat and noise, I used the how-to guides referred to above and also added the remnants of an old foam and fur push bike seat cover immediately under the leather? boot that the lever pokes through.
Quick and easy stuff like this I enjoy and it puts a bit of you into the car.
Postby bruce » Sun Jan 18, 2009 9:37 pm
Wouldn't Mazda spares be the cheapest place to get em?
Fatty
Postby Fatty » Sun Jan 18, 2009 9:53 pm
bruce wrote:Wouldn't Mazda spares be the cheapest place to get em?
noooooooooooooooo.
i think i got mine from mx5parts.co.uk
