Removal of Intake Manifold
Szemen
Postby Szemen » Thu Jan 15, 2009 9:08 pm
I managed to get all 9 bolts off that hold the intake manifold, however, I can't disconnect the silicon/ (dunno what its made out of)/rubber fuel line from the Rigid fuel line. This is the one near the overflow tank...Anyone got any tips?
I'm removing it to get to the oil filter that has 2 hoses going to it....One of the hoses is leakin ><
MOST GODDAM AWKWARD PLACE TO LEAK!!!!!!
Steampunk
Postby Steampunk » Thu Jan 15, 2009 9:59 pm
jam a very small, ie jeweler's, flat-head screwdriver between the rubber (not silicon) hose and the hard-line, work the screwdriver around and jimmy it off.
If you bought a replacement hose, then just cut it off with a Stanley knife.
Postby Okibi » Fri Jan 16, 2009 12:14 am
I think they recommend loosening your fuel cap first to remove any pressure it's holding.
Szemen
Postby Szemen » Fri Jan 16, 2009 12:29 am
I tried to jimmy it with a small flat head, lever it out with a small flat head..both didn't work. It feels like its fused ahahah...or shrunk onto the rigid line. I'm thinking of getting some boiling water. Soaking a towel through it and wrapping it to soften the rubber hose.
As for the fuel cap, I didn't think of that until later on tonight, opened up the fuel cap...SCHWOOP! sucking in all this air. THen I though..HEY PRESTO! but no :( Just as tight.
Woo
Vehicle: 10AE - Turbo
Postby Woo » Fri Jan 16, 2009 12:32 am
Move the clamp out of the way and twist it with a pair of multi grips or coarse pliers to break the seal. You should be able to jiggle it off once the seal is broken.
Bazz
btw, they are oil cooler lines going to the filter base
Very slightly modified 10AE #2562 ..... one of 149 in Australia :wink:
Race what you brung ..... And hope you brung enough
Damo
Postby Damo » Fri Jan 16, 2009 12:36 am
I've had no luck with various screwdrivers so just cut it off. They seem to be the hardest hoses to remove.
NB8A (2000 Highlight Silver), KU36, Kaaz LSD, QFM A1RM, Mazda Competition engine/differential mounts, Town & Country cat-back.
Szemen
Postby Szemen » Fri Jan 16, 2009 12:54 am
Woo wrote:Move the clamp out of the way and twist it with a pair of multi grips or coarse pliers to break the seal. You should be able to jiggle it off once the seal is broken.
Bazz
Yea, thats the hose I'm trying to get to with all my might!
And I can't just cut it off...I don't have a spare fuel line :( and that's is quite important in the operation of the car aahaha. I'll try breaking the seal tomorrow...If not... I'll get lazy and just ring my mechanic to get him to drop on over :P But I really hope its ready for Sunday :(
Szemen
Postby Szemen » Fri Jan 16, 2009 11:29 am
Genius! =D Its moving! :P Should be ok for SUnday *fingers crossed*
Woo
Postby Woo » Fri Jan 16, 2009 11:48 am
Glad it worked out for you 8)
Postby sliq » Fri Jan 16, 2009 11:55 am
see. i love this forum.
