SP spark plugs
mazlot
SP spark plugs
Postby mazlot » Sat Jan 03, 2009 3:27 pm
What are your recommendations ?
Farken Gruven
Daz
SP spark plugs
Postby Daz » Sat Jan 03, 2009 4:05 pm
I think the popular choice is (NGK) BKR7E11, the 7 has something to do with temperature and I think the stock ones are 5. I changed mine over to this model in iridium years ago and they seem good... no issues.
Silver SP - PSS9, 1:10:58
blackster
SP spark plugs
Postby blackster » Sat Jan 03, 2009 6:32 pm
Daz wrote:I think the popular choice is (NGK) BKR7E11, the 7 has something to do with temperature and I think the stock ones are 5.
The heat range refers to how much heat a spark plug is capable of removing from the combustion chamber. A spark plug with the proper heat range will insure that the tip will maintain a temperature high enough to prevent fouling yet be cool enough to prevent pre-ignition.
Previous
04' MX5 SE.
02' MX5 Classic ed.
bigdog
King of the kennel
SP spark plugs
Postby bigdog » Sat Jan 03, 2009 7:03 pm
6's are the standard SP plug, most of us run the 7s, if you've upped the boost you can run 8s - Dave uses these in his. 5s are way too hot a plug for an SP. As I understand it from the dyno tests done on MX5s there is no performance benefit in running iridium plugs, just a longer plug life. Given the cost I would go (and have) the BKR7E11 route and change them more often.
Garry
SP spark plugs
Postby Garry » Sat Jan 10, 2009 10:54 pm
What they said, 7's, though Mazda will probably want you to fit 5's or 6's.
Woo
Vehicle: 10AE - Turbo
SP spark plugs
Postby Woo » Sun Jan 11, 2009 12:07 am
Depends on the boost you're running.
6's are good with a good tune (ie standalone), otherwise 7's for up to 15 psi. You may need to close the gap if you run 7's (0.7 mm).
If you're running bigger boost go for the 8's but as suggested check for fouling (0.7-0.8mm)
Bazz
Very slightly modified 10AE #2562 ..... one of 149 in Australia :wink:
Race what you brung ..... And hope you brung enough
