Roadster Cat
madboy
Roadster Cat
Postby madboy » Mon Dec 29, 2008 11:35 am
Hi guys,
I am getting the "heat" light on my dash from the import roadster's cat converter, starts out very faint, gets slightly brighter after a few minutes, I understand that this is not something essential for aussie epa standards?
Is there a fuse somewhere i can pull to turn this thing off? what happens if i remove the stock cat for a high flow? does this thing affect the ECU is anyway?
cheers
MB
grump
Roadster Cat
Postby grump » Mon Dec 29, 2008 11:38 am
My light comes on when I turn the ignition on but goes off when I start the car.
mx5racing
Roadster Cat
Postby mx5racing » Tue Dec 30, 2008 10:50 am
If its an original 89/90 model then there is a plug you can disconnect next to the cat. Follow the wire from the the sensor in the cat and you will find it. It's just a plastic one that easily disconnects. Won't affect the ECU/tune at all so you can fit any style of cat.
If the cat is overheating its usually due to unburnt fuel that may have caused a partial blockage of the cat which restricts the flow and gets hot. Dodgy O2 sensor can be the cause of it, along with a few other things.
We use a infa-red thermometer to check cat heat so perhaps see you local exhaust guys to see if they have one - they are a great way to find all sorts of problems.
Be careful as a partially blocked exhaust can get incredibly hot. Even when some parts can be touched others will fry your hands!!
madboy
Roadster Cat
Postby madboy » Tue Dec 30, 2008 11:38 pm
mx5racing wrote:If its an original 89/90 model then there is a plug you can disconnect next to the cat. Follow the wire from the the sensor in the cat and you will find it. It's just a plastic one that easily disconnects. Won't affect the ECU/tune at all so you can fit any style of cat.
cheers, for that info, dodgy O2 sensor would make it run rich right? might be causing the backfire's i am getting when shifting into 2nd after planting it?
