Coolant pipe replacement
madboy
Postby madboy » Tue Dec 23, 2008 11:57 pm
Hi guys,
as part of getting the BRG and tan back up to a decent condition, it looks like all the coolant pipes need to be replaced.... the 3 that run from the inlet manifold are all leaking at the ends(they are still using factory pipe clamps)...do you just use some straight heater pipe for these? i can't seem to find replacement aftermarkets for them anywhere?
also, what side of the fence do you stand for the other 5? rubber or silly cone? also, almost every book i have looked in and every place i go only lists and upper and lower for the main pipes, whats up with the 3rd one? more straight pipe?(sorry, i haven't had a chance to jack it up and get a good look under the motor)
cheers
MB
SuperMazdaKart
Postby SuperMazdaKart » Wed Dec 24, 2008 4:09 am
by pipe you mean hose?
the two bottom hoses are the same as each other. get rid of the tension clamps for hose clamps that adjusted by a screwdriver.
Garry
Postby Garry » Wed Dec 24, 2008 10:41 am
The 2 coolant hoses on my throttle body were leaking. The rubber had hardened up and expanded and the factory clamps couldn't squish the hose tight enough. I replaced the factory clamps with some screw ones but the hose had deteriorated to much and the clamps just chopped up the hose. I got 2 new hoses from Mazda yesterday for $19 each.
Juffa
Postby Juffa » Wed Dec 24, 2008 10:52 am
I changed some of my hoses on a previous 5 restore. I found that as I changed some hoses others would start to leak. I suggest replacing them all and as already mentioned get some adjustable hose clamps.
As for rubber or silicone. I have an silicone upper radiator hose. It leaks at both ends and I have since found out that most forum members that bought the same hoses as part of a group buy have had the same problem. I am going back to the original rubber hose.
I didn't have much luck finding non original hoses, so I ended up giving my local dealer some serious cash.
J
wun911
Postby wun911 » Wed Dec 24, 2008 6:51 pm
I got new coolant hose top and bottom I think NA hase 3 and NB has 2.
Very hard to find aftermarket (non Mazda) hose for NB, my Mazda dealer wanted $90 for bottom hose and $50 for the top hose :shock:
The old ones were starting to swell up when the car got hot, now its keeps its shape better.
I use T bolt clamps to hold them on no leaks or problems on the track.
every ounce counts
tbro
Postby tbro » Wed Dec 24, 2008 8:17 pm
Hi MB,
If your car is a NA try this site
http://www.boundville.co.uk
They have I think all of the hoses for 1.6 and 1.8.
I did a group buy earlier this year and i think everyone was happy with the quality.
I also second using screw clamps and throwing the factory to the sh*t bin.
Terry
madboy
Postby madboy » Wed Dec 24, 2008 11:57 pm
thanks for the replies all, yes sorry i have an NA, so 3 main coolant hoses, 2 heater and 3 for the manifold. Proper hose clamps are defiantly on the cards, those pre tensioned things are shite,
SuperMazdaKart wrote:by pipe you mean hose?
so thats why they only list 2 hoses? because the two bottom ones use the same hose? this is gonna get expensive
