Match the Symptoms ? Random 'dying' and Disconnected TPS !
kazjim
Postby kazjim » Sat Dec 20, 2008 4:12 pm
So, yesterday took it for a little run up the OPH ... (berowra to gosford) and if i took the revs over about 6kish, the next gear change would just 'die'
I was thinking i had just received a bad batch of fuel and my filter was clogged ....
lifted the bonnet this morning and saw the Throttle Position Sensor lead sitting about an inch away from the TPS !
So, would that explain my symptoms ?? :oops:
Anyway, picked up new fuel/air and oil filters and will give it a full service tonight !
J
If my calculations are correct, when this baby hits eighty-eight miles per hour ... you're gonna see some serious s**t.
CT
Postby CT » Sat Dec 20, 2008 9:24 pm
Disconnecting the TPS stops the fuel pump in NB models and obviously stops sending the required ignition signals to the ECU. That will cause problems......
kazjim
Postby kazjim » Sat Dec 20, 2008 9:27 pm
Did the service not long ago .... wowee !
now i think i understand ... smooth all the way to 7k, sounding sweet and pulling like a 1.6 shoudnt !
had fun, great thanks !
J
