hey guys, recently the friction point of my car has moved up to the extent that there is no deadzone. I think i need to adjust the clutch cable so that the friction point moves down a little. How can i do this?
cheers
NB8B Clutch cable adjustment
- Caffeine
The clutch is hydraulic, there is no cable.
Sounds like your slave cylinder is dead, quite an easy fix, ~15 minutes to replace with a new one ($50 ish)
i've read that if it is leaking, it should leak clutch fluid. I just topped up my reservoir, so i guess if it is leaking the reservoir should drop yes?
or, if i do need one, where can i get one for NB8B?
lift the boot on the slave if its wet its leaking....
every ounce counts
Stevesports my recollection was that there is free play adjustment under the dash- you must have some lash in the set up. The slave cylinder is simply a hydraulic pump with no adjustment that I am aware of. I do recall reading somewhere about the adjustment technique for the 5 - suggest have a look at Miata site.
