Engine Swap and Clutch Replacement ... what else do I need?
Posted: Tue Nov 25, 2008 11:38 pm
by NMX516
Worth replacing the thermostat, and I'd have a close look at the alternator and regulator and also the starter motor...
Might as well do the fuel filter too.
Posted: Wed Nov 26, 2008 12:03 am
by SuperMazdaKart
how many k's is on the donour engine & what does it have on it?
if it still has it's timing belts/& other belts on & they aren't near the due replacement date then i'd be inclined to leave them on which would save you a timing belt change & few other parts that go with it. otherwise could re-use the belts from the retiring engine if they have enough kilometres in them to last till the next engine change. just don't twist/bend the belts.
my engine swap list is at
http://www.mx5cartalk.com/phpBB-3.0.2/viewtopic.php?f=18&t=32405&p=416932&hilit=nb6#p416932 but not all of it would apply to yours.
& make sure to be particularly careful with the heater hoses going into the heatercore.
Posted: Wed Nov 26, 2008 9:18 am
by Matty
front and rear gearbox seals.
Posted: Wed Nov 26, 2008 10:44 am
by fattima
Rubber blanking plug on back of engine, I'd tap it and use a hex plug while the engine is out.
Posted: Wed Nov 26, 2008 12:51 pm
by Mr Morlock
If the engine you are intending to replace for a a short period ( how many KM's are you doing) is in reasonable condition I would be doing just the minimum. The planned maintenance thing- ie replacing parts that are ok can get out of control- refer Supermazda's comments. Clutch is of course probably essential. I would leave the bolt on "accessories" alone. But its your money.
Posted: Fri Nov 28, 2008 11:18 pm
by Steampunk
Check the 2 thin coolant hoses that run from the back of the engine towards the front via underneath the inlet manifold. If they look ok leave them, but if you feel the need, then this is the best time to get to them.
Even though the donor engine has low km's, if it has been sitting unused for a lengthy period, then perhaps add the water-pump to the list as the seals perish due to lack of use.
Posted: Sat Nov 29, 2008 5:21 pm
by JBT
Flywheel spigot bearing if it's not included in the clutch kit.
Posted: Sat Nov 29, 2008 11:03 pm
by mr_rotary
1red5 wrote:Check the 2 thin coolant hoses that run from the back of the engine towards the front via underneath the inlet manifold. If they look ok leave them, but if you feel the need, then this is the best time to get to them.
Don't forget the little rubber nipple on the back of the block on the driver's side! Only a 40c part and if you got the engine out, so much more easier to replace!!!
Posted: Mon Dec 01, 2008 7:37 pm
by ASE05
mr_rotary wrote:Don't forget the little rubber nipple on the back of the block on the driver's side! Only a 40c part and if you got the engine out, so much more easier to replace!!!
Can you translate that into mazda OEM speak for me?
Posted: Mon Dec 01, 2008 9:39 pm
by SuperMazdaKart
some alcohol for afterwards?
Posted: Tue Dec 02, 2008 8:12 pm
by sabretooth
List looks pretty good to me. If I get off my lazy ass I'd get my site up so you can see what I did when rebuilding my engine - to see if you missed anything.
Sounds pretty well-covered to me though.
