Might as well do the fuel filter too.
1red5 wrote:Check the 2 thin coolant hoses that run from the back of the engine towards the front via underneath the inlet manifold. If they look ok leave them, but if you feel the need, then this is the best time to get to them.
Even though the donor engine has low km's, if it has been sitting unused for a lengthy period, then perhaps add the water-pump to the list as the seals perish due to lack of use.
mr_rotary wrote:Don't forget the little rubber nipple on the back of the block on the driver's side! Only a 40c part and if you got the engine out, so much more easier to replace!!!
