CAI Tubing
pcmx5
CAI Tubing
Postby pcmx5 » Thu Nov 20, 2008 9:52 am
My MX5 factory CAI has black flexible tubing between the cannister and the firewall(wire ribbed fabric)
It has worn through by rubbing against the pipe on the firewall above and i want to replace it with a better, smoother pipe.
I will need to incorporate a bend as the cannister sits below the level of the hole in the firewall.
Has anyone got any suggestions about material to use and where to get it?
Will probably visit a plumbing shop to see if they have anything with an angle bend suitable in plastic but any help greatly appreciated.
Peter
Matty
CAI Tubing
Postby Matty » Thu Nov 20, 2008 10:02 am
PVC pipe + heatgun.
Failing that, get some mandrel bends from an exhaust shop or have them make up something.
trader
CAI Tubing
Postby trader » Thu Nov 20, 2008 10:37 am
ImageImage[url][/url]
I dont know if you have a cone filter pcmx5 but this is what it looks like. Off centre but doesn't worry me. I used a PVC collar and 4" pipe from Bunnings. The reducer is a cut down thermos flask from Go-lo or similar. All fits together nicely and then painted with bumpercoat. Costs around $40.
NB SE, NA 1.8.
pcmx5
CAI Tubing
Postby pcmx5 » Thu Nov 20, 2008 12:16 pm
Thanks for the responses.I have got some more fabric like before, but may explore the plastic option.
trader, your setup looks very neat
Peter
Fatty
CAI Tubing
Postby Fatty » Thu Nov 20, 2008 4:59 pm
hi peter,
where did you get the new pipe? i have the same CAI as you and my pipe is frayed too.
Locutus
CAI Tubing
Postby Locutus » Thu Nov 20, 2008 6:00 pm
while we're on the topic, has anyone tried fitting a bellmouth to the end of the cowl intake tube?
CAI Tubing
Postby Jeo » Thu Nov 20, 2008 7:37 pm
Locutus wrote:while we're on the topic, has anyone tried fitting a bellmouth to the end of the cowl intake tube?
I was always curious about this too...
Matty
CAI Tubing
Postby Matty » Thu Nov 20, 2008 7:39 pm
yeah, I used a flared speaker port from Jaycar. But they don't sell em anymore.
Not sure if it made any difference - the trouble is you have to fit it into the cowl area... Didn't do any measured comparison between it and the straight tube.
SuperMazdaKart
CAI Tubing
Postby SuperMazdaKart » Thu Nov 20, 2008 11:01 pm
sorta.. cept on the cowl itself.
pcmx5
CAI Tubing
Postby pcmx5 » Fri Nov 21, 2008 8:36 am
Fatty wrote:hi peter,
FATTY,
I ended up with two types both flexible one cloth and one plastic.Used the plastic one,
i cut the wire out of the end that was going to the cannister to make it easier to stretch over.It is 85 mm I think.
Where did I get it? At an engineerining supply company owned by my partners family!!! Last place i thought of,in fact it was suggested to me by someone else.They had lots of different sizes so i am sure a similiar company near you could help.
cost $5.
cheers,
Peter
Fatty
CAI Tubing
Postby Fatty » Fri Nov 21, 2008 3:54 pm
thanks for the help peter, cheers.
