running rough
mossy
running rough
Postby mossy » Fri Nov 14, 2008 1:55 pm
I just converted the 96 mx5 back to standard got it running and went for a couple of drives and all seemed well. Went to start it the other day and it idled really rough and does the same when I rev it as well, I changed the ignition leads to new ones but that didn't make a difference, it also smells like its running rich, any ideas?
ampz
running rough
Postby ampz » Fri Nov 14, 2008 3:24 pm
Mossy, you had a FFS on that yeah?
If so, did you change the injectors to run the FFS or just use yours standard ones + extra injector?
I'm taking a guess at maybe some wiring has worked loose (unless you used a patch through harness) and your ecu is in limp home mode (do the NA8s have a check engine light?).
Check for an oxygen sensor signal, an injector stuck open (put a screwdriver on the body of each injector, then you ear to the handle, you should hear a clear ticking sound, if it is muffled the injector is stuck open) a vacuum leak from one of themany fittings.
Maybe you have too much fuel pressure (the regulator may be flowing too much)
Huh?
mossy
running rough
Postby mossy » Fri Nov 14, 2008 4:00 pm
I ran the stardard injectors but I never got in running right as it was running way rich, maybe it has clogged the cat from then? I couldn't find a loose vacuum hose and I've put in new spark plugs and had the injectors cleaned last week.
ampz
running rough
Postby ampz » Fri Nov 14, 2008 8:00 pm
What about the throttle body?
Was that relocated to the front of the supercharger?
If so, did you get a new gasket to put it back on the inlet manifold?
I tore mine after doing a couple of mods to the t/b and it was a bit weird for a while (I made a new one out of card).
I'll think about it a bit and If anything comes up I'll yell out.
Huh?
mossy
running rough
Postby mossy » Sat Nov 15, 2008 11:50 am
I played around with the leads and wiggled the leads at the coil pack quite a bit and it ran a bit better then I started it this morning and it runs fine :roll:
