I got a PWR rad and I finished installing it today, just some notes if anyone is thinking of getting one now that summer is here.
Fits into the car kinda, I had to bend the metal hooks that hold the rad in place at the top (otherwise it will rattle a bit).
Both fans need to be cut and trimmed around the edges so that it can fit flush to the rad. (Weight reduction, was happy to do it)
Holes to bolt the fans on were a bit off. On the (AC fan) you will need to drill some new holes and or make some of the existing holes larger.
On the other fan you will need to make one or both of the holes slighly larger.
It now takes 6.5 L of liquids in total (a bit more weight), the PWR weighs about 2 kg more than OEM so maybe ~3.5 kg of added weight in total
It looks like there is plenty of room for thicker sway bar...
