Cracking Radiator
Garry
Cracking Radiator
Postby Garry » Fri Nov 07, 2008 12:28 pm
You can replace the top plastic bit but it's not all that much more expensive to get a full alloy radiator from Mania. As a reference I think my new top tank was a bit over $200 supplied and fitted after I removed the radiator from the car and took it to the guy.
Garry
Cracking Radiator
Postby Garry » Fri Nov 07, 2008 12:42 pm
It depends on the condition of the rest of the radiator. Luckily mine was in good nick. It was also an SP radiator and the guy that designed the SP cooling system recomended not to fit a thicker one (like Mania's) to an SP as it reduces the cooling system efficiency. So in my case it was a new radiator from Mazda *shudder* or getting mine repaired. Do a ring around and see what the prices are like in your area for new vs repair.
Steampunk
Cracking Radiator
Postby Steampunk » Fri Nov 07, 2008 12:43 pm
Around $80 for replacement top tank and clean from Red Devil Radiators.
It's a value-for-money fix IF the person who replaced it sealed it correctly. Mine started leaking after about 8 months. :evil:
Why not hunt around for a second-hand, low-mileage one as the going rate is around $100 or less. Boyracer has a couple doesn't he?
Garry
Cracking Radiator
Postby Garry » Fri Nov 07, 2008 1:02 pm
No idea how you got it done for $80. The tank alone for my car was around $150. The guy that did the job was shocked at the price of the tank. He said it was much more expensive than other cars he'd done. I rang several places and all were about the same money. Are NA top tanks cheaper to source?
GP
Cracking Radiator
Postby GP » Fri Nov 07, 2008 1:13 pm
$100 for my Na top tank fitted :D
Graham
Cracking Radiator
Postby sliq » Fri Nov 07, 2008 1:14 pm
yup, give boyracer a bell.
Cracking Radiator
Postby sliq » Fri Nov 07, 2008 1:39 pm
i think the standard radiators should do fine.. i never had a problem on my oem one apart from the top tank going very brown/on the point of cracking. no material need for the SE ones, because as you aforementioned, you won't be taking the 5 down to the track.
Garry
Cracking Radiator
Postby Garry » Fri Nov 07, 2008 2:25 pm
I must have had to pay the Sydney surcharge then. :(
mx52nv
Purple Porsche Eater
Cracking Radiator
Postby mx52nv » Fri Nov 07, 2008 7:54 pm
If you can afford it then I see no reason why you would not get an SE radiator 8)
Cracking Radiator
Postby Okibi » Sat Nov 08, 2008 1:44 am
Try e-mail Simon Corston (his e-mail address is on the W.A. club website) he may still have a spare SE radiator.
