Can someone tell what this part is?
apophis
Postby apophis » Wed Oct 01, 2008 4:30 pm
I have a NB8C 03 model with stock airbox.
This item has a lead ran into it, has power and ground to this plug. I pulled it out of the airbox and its just a plastic tip, I am suspecting that it is some sort of temperature sensor in the factory air box
If I get myself some pipes to make a CAI kit, do I still need this plug?
I am not afraid of your weapons, you know who the fk i am?
stevesports
Postby stevesports » Wed Oct 01, 2008 4:58 pm
as i understand, that is the O2 sensor
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Wed Oct 01, 2008 4:58 pm
pretty sure its an O2 sensor. yes you need it.
corners
Vehicle: ND - Supercharged
Postby corners » Wed Oct 01, 2008 5:06 pm
Thats an air temp sensor and I am not sure if you need it for CAI
Rotary
Postby Rotary » Wed Oct 01, 2008 5:10 pm
Its the Intake Air Temp Sensor
O2 is in the Exhaust.
It won't fuel properly without it (not sure if it will even start or may start but just run Open loop fuel mixtures)
for my CAI i fixed it just on the outside of the K&N filter
The closer to the suction the more accurate it will be.
The best place is just after filter before AFM
Alex
Postby Alex » Wed Oct 01, 2008 7:03 pm
Yep it's a temp sensor
if you are going for a pod filter just drill a hole in the top of it and insert sensor there
sabretooth
Postby sabretooth » Fri Oct 03, 2008 11:32 am
Most definitely not an O2 sensor! As per some of the posts in the thread, that's an air temperature sensor.
