CAS Rotation NA 1.8
JBT
CAS Rotation NA 1.8
Postby JBT » Tue Sep 30, 2008 3:06 pm
Rotate opposite to the direction of rotation of the camshaft to advance.
Matty
CAS Rotation NA 1.8
Postby Matty » Tue Sep 30, 2008 3:38 pm
Since you will be doing this with a timing light in your hand, it isn't hard to figure out.
Garry
CAS Rotation NA 1.8
Postby Garry » Tue Sep 30, 2008 3:43 pm
If the idle speed picks up then you have advanced the timing, if it slows down you've retarded it.
Steampunk
CAS Rotation NA 1.8
Postby Steampunk » Tue Sep 30, 2008 4:42 pm
CAS Rotation NA 1.8
Postby manga_blue » Tue Sep 30, 2008 7:44 pm
For the direct answer now ... as you're leaning over the front bar, holding the CAS in your left hand and facing towards the back of the car then turning it anti-clockwise advances it, turning it clockwise retards it.
It's a good idea to mark it first across the join with the CAS and the cam cover with a felt tip pen to remember where you started from.
