same timing belts?
RG.net
same timing belts?
Postby RG.net » Mon Sep 29, 2008 8:50 pm
does anyone know if the 1.6 and 1.8 timing belts are the same? i was planing to run a timing belt w/o air con, but gates dont seem to make them for the nb? i'm not sure if nb's came optional with a/c or not like the na's did. Does anyone know of any other timing belts that fit the 1.8 with out a/c?
thanks
JBT
same timing belts?
Postby JBT » Mon Sep 29, 2008 9:37 pm
That's a drive belt, not the timing belt.
RG.net
same timing belts?
Postby RG.net » Tue Sep 30, 2008 7:15 pm
ok then drive belt, isnt it the same thing? or is the b6-bp a special engine or something?
AJ
same timing belts?
Postby AJ » Tue Sep 30, 2008 7:30 pm
no, the drive belt (or fan belt) runs off the crankshaft to turn the alternator, water pump, power steering & aircon.
The cam belt (timing belt/timing chain depending on engine) runs off the crankshaft behind closed doors (cam belt cover) to keep the cams/valve train in perfect synchronisation with the crankshaft so the the engine does all it's stuff properly.
there is nothing special about the B6 - BP engine, it's exactly the same as any other internal combustion engine, they are all SSBB configuration, the glaring exception is the rotary which has no valve train.
in answer to your question, I'd ask a Mazda dealer (or ford), I'm sure there are plenty of other models that ran the 1.8 BP sans aircon, just a matter of finding one the right length :)
XMX5 Rogues
Fatty
same timing belts?
Postby Fatty » Tue Sep 30, 2008 7:37 pm
"engines for dummies" explanation:
drive belt outsidey engine, timing belt insidey engine.
RG.net
same timing belts?
Postby RG.net » Tue Sep 30, 2008 11:32 pm
intresting that, might need to have another look at my belt(s) then, i swear they are the same.
Rotary
same timing belts?
Postby Rotary » Wed Oct 01, 2008 9:49 am
MXHEVN wrote:intresting that, might need to have another look at my belt(s) then, i swear they are the same.
yeah the two belts you see are the same, but as the others have said neither are called timing belts. you'll have to start pulling your engine apart if you want to have a look at that one
JBT
same timing belts?
Postby JBT » Wed Oct 01, 2008 12:33 pm
I've never seen an NB in Australia without air con. :?
Anyway, see the attached diagram. It shows the part numbers for a USA market NB but should be similar for the Australian market. Check with a Mazda dealer.
RG.net
same timing belts?
Postby RG.net » Thu Oct 02, 2008 3:49 pm
wow i feel like a blonde :oops: i really should of known that, just had a look at the drive pully and saw the 2 belts. i was hoping to get a gates timing belt, i wonder if gates make a drive belt also (iirc moss motors states they do for the na, this is probably why i got confused)
RG.net
same timing belts?
Postby RG.net » Thu Oct 02, 2008 6:42 pm
ok gates only make timing belts, got the drive belt from my local repco, now i just need to change it ... any info? :oops: i was told the gold brackets loosen the belt but i have had no luck.
RG.net
same timing belts?
Postby RG.net » Thu Oct 02, 2008 7:06 pm
never mind, got it :D thanks guys for clearing everything up
TieNN89
same timing belts?
Postby TieNN89 » Mon Oct 06, 2008 11:58 pm
what do you mean gates do make a drive belt
i got both :)
ampz
same timing belts?
Postby ampz » Tue Oct 07, 2008 9:27 am
Gold brackets?
You have taken bling to a whole new level :lol:
Huh?
RG.net
same timing belts?
Postby RG.net » Tue Oct 07, 2008 4:13 pm
AZNTieN wrote:what do you mean gates do make a drive belt
i got both :)
must be the alternator and waterpump belt, i rang gates australia and they said they didnt make the p/s belt.
RG.net
same timing belts?
Postby RG.net » Tue Oct 07, 2008 4:14 pm
ampz wrote:Gold brackets?
hey, it was like that when i got it :lol:
i'm not really good at explaining things online, but i know what i am on about :mrgreen:
