3.9 diff gear ?
neil d
3.9 diff gear ?
Postby neil d » Wed Sep 24, 2008 12:41 pm
Who know where I can get my hands on some 3.9 diff gears cheap?
Where they only available in late modle mx5's or can you get them out of Van like the 4.4?
Any help welcome.
Neil
SP Race Car
RS Clio
ML 300
Hellmun
3.9 diff gear ?
Postby Hellmun » Wed Sep 24, 2008 6:36 pm
I think they were only in the 10th Anniversary edition MX5's over here. Pretty sure there is a Jap model with them though in the NB's, not sure if it was all 6 speeds but I thought the 3.606 was Australia only. Japan/Usa both got 3.9's.
Matty
3.9 diff gear ?
Postby Matty » Wed Sep 24, 2008 9:40 pm
yeah, find a US turbo owner and arrange a swap for a 3.6
corners
Vehicle: ND - Supercharged
3.9 diff gear ?
Postby corners » Thu Sep 25, 2008 2:52 pm
I have a standard NA diff you could buy. I am not sure of the ratio though..
Hellmun
3.9 diff gear ?
Postby Hellmun » Thu Sep 25, 2008 5:53 pm
I think NA6A's are 4.44:1 and the NB8A and NA8's were 4.1's. So your diff isn't the 3.9 he's after.
flycasta
3.9 diff gear ?
Postby flycasta » Thu Sep 25, 2008 8:28 pm
The gears used in the NB's are the same that were in the Early Mazdas like RX2/Capella, Series 1 / 2 and 3 RX7's.
I have a diff centre with a set if you want them.
If you have an NA I'm not sure.
Duane
neil d
3.9 diff gear ?
Postby neil d » Fri Sep 26, 2008 9:47 am
flycasta wrote:The gears used in the NB's are the same that were in the Early Mazdas like RX2/Capella, Series 1 / 2 and 3 RX7's.
Thanks for all of the reply's
I have an NB8c from Japan (now my SP race car) which came with a 6 speed and a 3.9 torsen.
I also have a standard NB 4.1 which I have a Kaaz Centre for but I want to stick to the 3.9 ratio and keep the torsen as a spare.
So I'm only after the 3.9 gear not a diff or a centre. If you have a 3.9 gear I will happily buy it of you Duane?
Neil
SP Race Car
RS Clio
ML 300
flycasta
3.9 diff gear ?
Postby flycasta » Sat Sep 27, 2008 9:42 am
Neil
I can strip the diff centre and take the gears out for you.
Would you like any photos first?
Duane
neil d
3.9 diff gear ?
Postby neil d » Sat Sep 27, 2008 7:47 pm
flycasta wrote:Neil
Duane
No need for photos but how much do you want for the gears and how old are they?
Feel free to pm me if thats easier
Neil
SP Race Car
RS Clio
ML 300
flycasta
3.9 diff gear ?
Postby flycasta » Sat Sep 27, 2008 8:07 pm
Moved to pm
