Timing light and NA6
With the battery in the boot for an NA6, where do you connect the possitive and the negative for the timing light?
- SuperMazdaKart
theres a blue plug near the passenger side headlight if your timing light has small aligator clips that can go into it.
or if you have jump starting leads, connect them to the battery in the boot & then the timing light cords to the jump starting leads. tis what i did.
Phew, had thought this and thought there was some stupid simple way that I had missed.
