Injector Cleaning in Sydney/Gosford??
Dweezle
Postby Dweezle » Fri Sep 19, 2008 11:57 pm
Does anyone know of a reputable place to get my Fuel Injectors cleaned / tested?
Just trying to sort out the entire fuel delivery system, starting with pump, filter and want to know its all tip top :roll: yeh, weird i know..
I live in Gosford, but Sydney is fine also.
Anyone had any experience with a premises??
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
blackster
Postby blackster » Sat Sep 20, 2008 12:27 am
If you stroll over the to the ausrotary forum, there is a user by the name of mazbit, who does injector cleaning & flow testing. His located in liverpool, apparently he offers postage service if your not prepared to travel.
I havent used his service personally, however I believe a few others on this forum have.
Previous
04' MX5 SE.
02' MX5 Classic ed.
whoa_dang_96
Postby whoa_dang_96 » Tue Sep 23, 2008 12:58 pm
John Collins Dyno Tuning in Newcastle (5 Tara Road Broadmeadow 49614961) can remove, flow, clean, reflow and reinstall for you at good prices. They also have all the seals and pintle caps in stock so they are "properly" cleaned in a sonic bath. They do all my injectors and have never had a problem - Ask for Nathan (John is always a bit busy - always)
They can also dyno your car (incase the name didnt give it away) so maybe you could request a ramp run before and after if you really wanted to see if there was a difference.
NOTE: there is always a risk of leaking injectors after a "proper" clean - who ever you go to and especially common on Toyota injectors. The injector needle can sometimes inmbed grit into the seat on the injector, so when they are cleaned the imbedded grit falls out and the injector cannot seal properly when closed (sorry if I have over simplified this)
