gearchange
nick viner
gearchange
Postby nick viner » Fri Sep 19, 2008 9:29 pm
My gear box is snicking teeth moving from 1st. to 2 nd gear.
Have changed gear oil and added nulon. No change .Car done 87.000 kms 2002 NB LE
Changes OK if done slowly. Anyone any ideas?
Matty
gearchange
Postby Matty » Fri Sep 19, 2008 9:56 pm
shagged synchros most likely.
Try Redline oil (everyone raves about it)
I'm running 1/2 Castrol synthetic g'box oil, 1/2 Castrol Dex-3 ATF to try to fix the same problem. Seems to work OK but I haven't tried much else...
Could also be the hydraulics (slave or master cylinder) failing, but that would affect all gears.
Keith
gearchange
Postby Keith » Fri Sep 19, 2008 10:40 pm
lol still worth checking the clutch hydraulics first. Although I agree it usually affects all gears, sometimes- it doesnt. I recently had a problem selecting 1st and second in the wife's car. Turned out to be clutch slave in the earliest stage of going awol. no visible leaks, no noticeable reservoir loss, but a slight weep ( all the leaked fluid- maybe 1/2 teaspoon full) was contained in the slave boot. Was just enough to reduce the actuating rod travel to make the low gears hard to select without grating. ( these spin faster than the higher gears, I presume).New slave fixed problem. Hope yours is as easy. I only investigated the slave in desperation after deciding the synchro was shot and the gearbox had to come out.
O6 Marble white NC ;91 Malibu Gold NA 1800 BP4W;1990 BRG LE hardtop, unmolested, original; 1993 Brilliant Black hardtop, unmolested, restored.
Insurgence
gearchange
Postby Insurgence » Fri Sep 19, 2008 11:40 pm
Hi all,
I get a similar thing on my NB8A:
when it's cold in the morning, sometimes the teeth will grate when 1->2 even when i have the clutch 100% depressed.
seems to work find when warmed up.
apparently the slave was replaced 2 years ago... how often do these things go bad?
NB8A
nick viner
gearchange
Postby nick viner » Sat Sep 20, 2008 7:33 am
Thanks guys . Yes it is worse when cold and it doesn't happen every time.
gearchange
Postby Mr Morlock » Sat Sep 20, 2008 11:45 am
Nick and Insurgence- the old cold snick is normal and perfection betwixt 1 and 2 at any time is not always achievable. It is a matter of degree. There are a number of threads about Redline though it is certainly not mandatory to use this oil- if the irritation is too great it might help. Keith's advice describes what is a common problem and worth keeping an eye on.
nick viner
gearchange
Postby nick viner » Mon Sep 22, 2008 7:49 pm
Thanks Mr Mortlock, Note taken
nick viner
gearchange
Postby nick viner » Tue Sep 23, 2008 10:38 pm
Seems to be nearly normal today. That's odd
nick viner
gearchange
Postby nick viner » Wed Sep 24, 2008 7:35 pm
Yes DaleZ ,I agree mine, has started to behave it's self. Work that out . temp may be a contributor
Garry
gearchange
Postby Garry » Thu Sep 25, 2008 9:22 am
Or you could check this if it's an NB8B+
http://mx5cartalk.com/phpBB-3.0.2/viewtopic.php?f=29&t=32467
It made a big difference to the gear change quality in my car.
