do apologise but another o2 sensor problem
Steampunk
Postby Steampunk » Thu Sep 11, 2008 4:01 pm
AZNTien replaced his recently.
Garry
Postby Garry » Thu Sep 11, 2008 4:39 pm
You need a 4 wire sensor, no idea of the part number though.
Postby bruce » Thu Sep 11, 2008 6:11 pm
Interesting username.
RG.net
Postby RG.net » Fri Sep 12, 2008 12:32 am
you will need 4 wire
part number is NGK OZA527-E1 ask them to look for similar part numbers and they should come up with a generic. a few people have been having problems finding a 4 wire, so just ring around. i know smithfield repco has them, (may need to order some though) ask for alan, weekdays and tell him adam sent you for a 02 sensor for a mx-5, that is ofcourse if you are in sydney.
TieNN89
Postby TieNN89 » Fri Sep 12, 2008 11:25 pm
miaturd wrote:hahah of course im in sydney i bought the exhaust off u adam!!!! its andrew HHAHAHAH and yeah my username is based off the evo gold coloured nb i have XD thanks heaps for the part number will be going into repco today
roflmao!
i bought mine from Autobarn ACA brand OX204
MXHEVN how much was yours?
RG.net
Postby RG.net » Sat Sep 13, 2008 1:03 am
wow, small world :D goodluck with it
RG.net
Postby RG.net » Sun Sep 14, 2008 3:39 pm
miaturd wrote:i got the ngk from auburn autobahn! alot more helpful guys there and i got it for $79 which i think is alright considering repco were charging me $120!!! and do any of you guys have tips on removing the o2 sensor?? ive been trying to get my spanner into there but it seems like its nearly impossible to get the head onto the top of the sensor >.< do i have to remove the heat shield?
Oh yeah and thanks for the model number adam =)
no problem andrew, did you ring smithfield repco? alan could of got it for you for $60! alwell.
i removed my heatshield (probably dont need to, cant remember) and used WD-40 to lube it up a bit (make sure the headers are COLD), then i was tossing up which way to get it off, i ended up taking the wheel off and going through the hole and loosening it. i have since forgoten on what the wiring combination is, what colour wires came on the ngk plug? you wil need to snipp off the connector as it isnt the same as ours. you will also need to snipp off the 02 sensor from the wires, then crimp male and female plugs on all wires and merge together. i will try find which wires go where for you.
