Page 1 of 2
Broken alternator belt
Posted: Tue Aug 05, 2008 7:33 pm
by bensale
I broke an alternator belt on the way home today... Seems like a faily odd thing to break...
I was just wondering if its a common problem or could be an indticaton of something more major. I know that it was most likey it was just due to age (no idea how old it was) or incorrect tension but I'm still interested.
Ben
Posted: Tue Aug 05, 2008 7:40 pm
by SuperMazdaKart
probably age..
they don't last forever. probably a good idea when replacing to get the powersteering & airconditioning belts done as well if you have them.
Posted: Tue Aug 05, 2008 7:49 pm
by Fatty
i replaced mine last year coz it was old, worn and frayed and looked like ti was due to break anyday. i'd say it's just one of those "consumable" items that need replacing every now and then.
my haynes manual recommends all belts should be inspected / adjusted / replaced at 6 month intervals, and details the procedure. if you don't have a manual ben, it's worth getting one as they come in very handy from time to time.
Posted: Tue Aug 05, 2008 7:54 pm
by bensale
I've got a manual James, perhaps I should have had a look at that section and done so hey?
And I think that you are both probebly right, just age. Bit of a PITA to have to get a flat bed home, my poor car
Ben,
Posted: Tue Aug 05, 2008 10:55 pm
by adherent
I'm told you can do a quicky fix to get you home using panty hose.
Half your luck if you can lay your hands on a pair that quickly ...
Posted: Tue Aug 05, 2008 11:48 pm
by TieNN89
Is there anyway of inspecting the timing belt without removing the rocker cover
Posted: Tue Aug 05, 2008 11:59 pm
by SuperMazdaKart
take off the lower timing belt cover, (not the rocker/valve cover one)
Posted: Wed Aug 06, 2008 12:17 am
by TieNN89
thats the black plastic thing just below the rocker cover yea?
Posted: Wed Aug 06, 2008 12:30 am
by SuperMazdaKart
think it is black on the NBs yeh
Posted: Wed Aug 06, 2008 9:59 am
by ampz
If you have power steering and air conditining you could have used that belt to get you home.
Of course you would then need to replace both belts as it would have been stuffed by the v-pulleys as opposed to the ribbed ones.
Posted: Wed Aug 06, 2008 12:08 pm
by bensale
Ok so i've changed the alternator belt and i'm going to go back to autobarn and buy an aircon belt and change that too. I've found a possible cause of the problem, i'm a bit worried.... May update later...
Posted: Wed Aug 06, 2008 5:55 pm
by devolutio
alternator belt also the water pump belt? don't drive too far without one of those. definitely something worth changing as preventative maintenance. this happened to me on the freeway last year... not concerned about the alternator light being on i figured i'd take a look off the freeway. that was until my radiator cracked the plastic top tank and i got a face full of steam. actually had a spare belt behind passenger seat (that i never got around to installing).
Posted: Wed Aug 06, 2008 6:09 pm
by bensale
You are quite correct that the alternator belt also runs the water pump. It was when I saw the temperature guage move past where it normally sits that I parked the car and figured out what had happened.
Posted: Wed Aug 06, 2008 6:20 pm
by devolutio
when i heard the bang i look at the temp guage and it was more than a little over the normal temp. while plastic end tanks that can explode seem like a pretty crap way of saving weight, it saved my engine. i can't believe all cars don't come with dummy lights for temp. maybe they have a deal with the head gasket manufacturers.
Posted: Wed Aug 06, 2008 8:54 pm
by Mr Morlock
Ben did the right thing in pulling over. You can cook an engine very quickly. If you have the broken belt to examine ones that are on the way out will betray cracks and deterioration- just bend them opposite way to reveal. Age and oil do their job on belts.
