Now; let me think if there is a factory MX5 with around 135kw and lots of torque straight out of the box...
Garry wrote:That sort of power output is easy to get from an SE. Have a talk to Blackster. Though once you start getting a bit more power you might not be happy with only 135rwkw.
Best definition of 'drivability' I found from a brief search isMr Morlock wrote:The question was increase the power but retain drivability. More KW always comes with some penalty.
Referenced from here ->clicky.DRIVABILITY
Definition: The general qualitative evaluation of a powertrain's operating qualities, including idle smoothness, cold and hot starting, throttle response, power delivery, and tolerance for altitude changes.
Old Fart wrote:Hi Patience please as I know bugger all about Turbocharging.I am thinking about buying a Turbo SE, how do you increase the grunt factor without sacrificing drivability.I would rather improve the factory unit than reinvent the wheel but how.
.I am after about 180 RWHP with plenty of torque and like most I am on a budget.
Your thought please
Steve
Old Fart wrote:Hi Excuse my ignorance, would you mind spelling out what zorst 'etc' means. Thanks Steve
