rear end ratio advice
Posted: Thu Jul 31, 2008 3:01 pm
I currently have the stock 5 speed with the stock 4.1 rear ratio. My car has about 160 something rwkw and will probably go up bit with the future plans to maybe 200ish. I am considering putting in a 3.6 rear end ratio so that I will be able to use 2nd gear at qr for what I am currently using 3rd for turns 3 pretty much on and i will be able to use 3rd for turns 1 and 2. However will the higher geared rear end put too much stress on the box? I am thinking that the 5 speed will give up at some point at which time it will be a quaife semi helical gear set or a 6 speed. so if I go 6 speed i will need the 3.6 or the gearing will be useless but thats another store all together as I will need to get different headers. If the box will give up quicker then I wont do it but if it should be fine then I may. what do you guys think?
