From reading on miata net, this is potentially a symptom of imminent crankshaft failure, which concerns me
How far does it normally move?
I'll try any grab a video of it moving...
Okibi wrote:That sux Liam,
Take it to your mechanic and get the crank pulley taken off and check if the keyway is damaged.
Who did your timing belt change?
bjones wrote:OI You forgot the ARp head bolts, end caps, the T28 aswell just to add some spice to the rear wheels
