Page 1 of 2
CAI
Posted: Fri Jul 18, 2008 8:59 am
by muzza2
has anyone experimented with these?
has anyone got some photos of them fitted?
Posted: Fri Jul 18, 2008 9:14 am
by Steampunk
*1red5 shakes his head*
Posted: Fri Jul 18, 2008 11:17 am
by Rotary
Should be good for VCA (Vacuum Cleaner Attachments)
Posted: Fri Jul 18, 2008 11:30 am
by SuperMazdaKart
you could make one yourself for cheaper..
Posted: Fri Jul 18, 2008 2:05 pm
by Rotary
Main Issue with performance in mind is the bad flow generated from all those ribs
If the size is large enough, then that can make up for it slightly, as long as its placed between filter and MAF, not between MAF and throttle Body as this may reduce performance.
From the ones i have seen at parts stores the size doesn't look large enough, and there very Flimsy bending easily, which will affect performance
I have seen improved versions with a plasticy rubbery inside, these look ok when straight, but do crimple up when bent, so their better, but if used should be setup with that in mind
Posted: Fri Jul 18, 2008 3:18 pm
by wun911
I want one made out of CF man...
Not to mention tubes without ribs = less weight...
And the little box / heat shield for the pod filter I want that made out of CF too.
CF should be insulative so it should keep the air cool yer?
What are the calculations every 10 deg drop in temp is 1 kw??
Posted: Fri Jul 18, 2008 7:06 pm
by TieNN89
Thats a K&N kit for the MX-5
Posted: Sun Jul 20, 2008 4:23 pm
by Steampunk
you have to retain it.
Posted: Mon Jul 21, 2008 12:02 pm
by matt9111
Hey about these.....I went down to my local autobarn on the weekend and bought a crappy TFI Pod (IE..Hot Air Intake..lol) and also the adaption plate for the MX5. but on closer inspection I found out that my AFM, actually goes into the air filter box, and it looks like a sealed unit?
My air filter box also has a sensor plugged into the side of it. But im assuming it isnt neccessary because I pulled it out and started the car and had no dramas.
So how do I get the pod to fit the AFM if the AFM goes into the box?
The pods purely for the sound until further down the track when I get a real intake.
Posted: Mon Jul 21, 2008 12:10 pm
by Craig
matt9111 wrote:on closer inspection I found out that my AFM, actually goes into the air filter box, and it looks like a sealed unit?
There's 2 nuts underneath that hold it in place, remove them and then remove the AFM.
Posted: Mon Jul 21, 2008 12:25 pm
by Regie
get one of these!
http://www.mx5cartalk.com/viewtopic.php?t=32057ive just installed it on my car and its awesome!
Posted: Mon Jul 21, 2008 12:37 pm
by muzza2
2 problems with that.
1 yours its a 1.8
second, yours is a NB
mines an NA, 1.6....
Posted: Mon Jul 21, 2008 5:26 pm
by Regie
oh damn sorry dude
Posted: Wed Jul 23, 2008 4:13 pm
by Steampunk
muzza2 wrote:2 problems with that.
1 yours its a 1.8
Regie wrote:oh damn sorry dude
Hey, nothing to be sorry about mate.
It's not your fault he has such a crap model.
Posted: Wed Jul 23, 2008 5:02 pm
by muzza2
1red5 wrote:muzza2 wrote:2 problems with that.
1 yours its a 1.8
when the flag drops, the bull-sh!t stops ;)
any time, anywhere mate
