Gearbox refill point.
Steampunk
Postby Steampunk » Wed Jul 16, 2008 12:15 pm
No, that's the reserve light switch.
The fill plug is located further forward and a little lower than that.
It sticks out about 12mm and is square-shaped.
mx52nv
Purple Porsche Eater
Postby mx52nv » Wed Jul 16, 2008 2:58 pm
Hey Fundies,
What about a little hand pump?
You don't need a funnel and it'll come in useful if you want to get the diff topped up too...
Steampunk
Postby Steampunk » Wed Jul 16, 2008 3:24 pm
fundies wrote:Oops. It seemed to work alright anyway.
Yeah, but now you've overfilled it. :P
Gazbo
Postby Gazbo » Wed Jul 16, 2008 6:42 pm
fundies wrote:How is it overfilled. Took 2 litres as it should. :?:
You're supposed to fill it until the oil reaches the bottom of the fill plug opening and starts to overflow. Then the oil is at the correct level.
Daily: 2006 "C" Mazda3 SP23
Fun: 1993 NA6
TieNN89
Postby TieNN89 » Wed Jul 16, 2008 9:36 pm
to be perfect take the fill thing off and let the overflow drain out
just like the diff its meant to take 1 L but mine doesn't take that much
Sheck
Postby Sheck » Wed Jul 16, 2008 11:49 pm
i think my 6 speed barely held 2L, the 5 is much smaller. Theres alot of useful info in these forumites brains, best to let the excess drain out :)
TieNN89
Postby TieNN89 » Thu Jul 17, 2008 12:14 am
no need to drain the lot out
just open up the fill and let the excess drain out
wun911
Postby wun911 » Thu Jul 17, 2008 10:42 am
Oh dam I had thought the 6pd took less oil = less weight :frown:
Although we dont need oil in the turret so maybe we do weigh a bit less overall :D
every ounce counts
Steampunk
Postby Steampunk » Thu Jul 17, 2008 11:56 am
fundies wrote:So it's not overfilled then.
The proper fill plug sits lower than the reverse switch.
Sheck
Postby Sheck » Thu Jul 17, 2008 2:19 pm
Hahah not likely!! Have you pick one up before?! They are very heavy, prolly another 5-10kg more than the 5 speed.
If i could be bothered i'll weigh both out this weekend cause i have a dodgy 5 speed still laying about from the old days of drifting.
Dave
Garry
Postby Garry » Thu Jul 17, 2008 3:01 pm
But the fill plug doesn't have any wires coming out of it. :shock: Are you looking on the correct side of the transmission? The fill plug is on the passenger side.
Sheck
Postby Sheck » Thu Jul 17, 2008 11:46 pm
take a photo of both so we can clear this up, doesnt sound right. The plug you filled from/into was it square? ie you had to use an adjustable spanner not a hex or double hex to get it undone?
