is the airconditioning functioning? ie colder air coming from the vents? check under the bonnet that the belt is still on the engine.
I'm guessing that the idle up is working fine, but the compressor isn't putting any load on the motor. either belt is broken or the air con clutch isn't getting signal / is broken.
if the air con seems to be working... i got no idea.
A/C idle up issue
- Vehicle: ND - 2
- Vehicle: ND - 2
A/C idle up issue
did you work it out?
Users browsing this forum: No registered users and 19 guests
