Oh NO! Feeling sick - I broke something expensive
Posted: Thu Jul 03, 2008 7:26 pm
by adamjp
Well, I'm swapping over heads on my car right now. A set of oversize valves have been ordered from the US and will be here soon for the ported head so I'm using the other ported head for a few months.
I just put the camshafts into the swap head - and broke the inlet shaft in half! :cry: That will teach me to juggle a call from work with using a torque wrench. :x
I'm gutted, HKS 264 camshafts are not so easy to come by. :cry: :cry:
In the remote chance that someone has one, or knows of some magic trick that will allow this one to be put back together, please respond. I think it's humpty dumpty - it'll never be back together again.
Posted: Thu Jul 03, 2008 7:31 pm
by AJ
ouch :frown: ........ease up on the weetbix mate :(
Posted: Thu Jul 03, 2008 7:41 pm
by SuperMazdaKart
maybe check this out.
http://www.ozmazda.com/board/index.php?showtopic=7384&st=0&#entry127255
a whole HKS MX-5 racing engine comes up a lot less often then just a HKS cam
Posted: Thu Jul 03, 2008 7:43 pm
by adamjp
I'm not a member there - what price? what spec?
Posted: Thu Jul 03, 2008 7:46 pm
by SuperMazdaKart
heres quoting their sponsore JUSTJDM
[quote name='justjdm' date='Jun 26 2008, 07:31 PM' post='126529']
You won't see this again.
PERIOD...
Basicly works like this....
if you can't drive with a 140hp well 240hp anit going to help.
[font=Comic Sans MS]You have as much chance as seeing a cat take a dump on a frozen lake than seeing one of these again.
[color=#0000ff][color=#ff8c00]Now getting the Mx5 to boogie with the raw sound of an Irish banshee on heat with a serious crack problem easy.............
[/color]
YOU GET
1.6 hard reving bandit
*JUN bottom end
*HKS cams
*HKS gears
*HKS PLugs
*HKS headers
*Quad throttle bodies.
*HKS ECU
NEVER TO BE REPEATED
How much you say?
how about $5495
DROP IN AND GOOD TO GO
Just hope you can steer
[font=Times New Roman]DRIVE HARD
DRIVE HOME
DRIVE HARDER WITH JUSTJDM
[/font]
[/color][/font]
[/quote]
Posted: Thu Jul 03, 2008 7:57 pm
by adamjp
Nice spec - but way beyond my budget. Thanks.
Posted: Fri Jul 04, 2008 1:33 pm
by bruce
Ummm, $5000 or a couple of hundred for a new camshaft? Which is cheaper?
Posted: Fri Jul 04, 2008 1:46 pm
by SuperMazdaKart
well such an offer doesn't come up often, which is better value?.. take a loan & sell off your current engine/parts if you need to & want to.
i wonder if it's easily drivable in day to day traffic.
Re: Oh NO! Feeling sick - I broke something expensive
Posted: Fri Jul 04, 2008 2:12 pm
by Matty
adamjp wrote:In the remote chance that someone has one, or knows of some magic trick that will allow this one to be put back together, please respond. I think it's humpty dumpty - it'll never be back together again.
Could you take it to a cam shop (eg Tighe) and get them to degree it and make a copy?
Posted: Fri Jul 04, 2008 6:04 pm
by adamjp
I have already emailed Tighe.
They can build up a copy using one of my stockies as a blank. But by the time you include postage etc., even they recommend my getting a replacement from the US for less than $100 more.
I liked their forthright advice and wish I was actually going to use them, but I won't be this time around.
I'm not quite so angry at myself today, but I'm still pissed for such a mistake. The problem was a stuck lifter, it was in, but not totally square to the bore. When I torqued down it just jammed more and the cam lobe placed pressure on the shaft.
Lesson - Always lube the lifters and make sure they are IN squarely so they can compress.
Posted: Sat Jul 05, 2008 10:20 am
by Sheck
highly doubt it. anything built for high revs will be a b**ch to drive around town
Not neccesarily, it depends on the cam specs. I've seen a very drivable sprinter with 310deg cams but small lift that was still idling smooth and quite drivable. He said lift is what makes it 'really' lumpy.
Bad luck with the cams mate, just sold mine last sat too :(
cams
Posted: Sat Jul 12, 2008 11:35 am
by spikey
I have got a set of Maruha cams if you are interested $800 for the pair of them.
Posted: Thu Jul 17, 2008 11:58 am
by Steampunk
HKS
Available to buy individually :wink:
Posted: Fri Jul 18, 2008 8:31 pm
by adamjp
Hmmm... Someone must have contacted him to get one. 8)
With the current exchange rate they as $410 delivered for one. I'm sure you can guess how I know. :D
