fuel pump question
16bit
Vehicle: NB8A - Supercharged
fuel pump question
Postby 16bit » Wed Jun 25, 2008 9:54 am
if I install a new higher capacity fuel pump will I need to get a new tune done?
kula
Postby kula » Wed Jun 25, 2008 10:00 am
nope.
Your fuel pressure is regulated by the FPR, so it shouldnt really.
16bit
Postby 16bit » Wed Jun 25, 2008 10:03 am
brilliant
Garry
Postby Garry » Wed Jun 25, 2008 10:05 am
Unless your tune was limited by how much fuel you had available. With a higher capacity pump theoretically you could up your fuelling and run a higher tune.
16bit
Postby 16bit » Wed Jun 25, 2008 4:55 pm
don't think so but I am gearing up to have an e85 map done so I just wanted to check if it would effect my current map. thanks all.
Fatty
Postby Fatty » Wed Jun 25, 2008 6:36 pm
the walbro pump has more fuel pressure, hence it will deliver more fuel (effectively it's the same as upgrading to bigger fuel injectors). so i would've thought a new tune would be needed? :?
whilst i see what kula is saying about the fpr.. i thought the fpr is expecting a certain pressure, you give it a higher pressure to start with and it will output a higher pressure as well.
i could be talking out of my ass, but i had a feeling it does effect the tune.
Woo
Vehicle: 10AE - Turbo
Postby Woo » Wed Jun 25, 2008 11:03 pm
The regulator will increase the volume of fuel flowing back to the tank in order to keep the pressure at it's factory preset level.
So the pressure doesn't get higher unless the regulator cant handle the increased flow. This sometimes happens if you put a 255 LPH pump in instead of a 190 LPH.
The increased flow has some benefits due to the fuel being kept cool rather than sitting in the rail getting hot.
Very slightly modified 10AE #2562 ..... one of 149 in Australia :wink:
Race what you brung ..... And hope you brung enough
