Can you please be more specific regarding the shaking.
Where do you think it's coming from?
Is it fast shaking, or slow?
Is it making any unusual sounds?
How many kilometres has your car done?
etc.
car shaking badly
- Steampunk
- Alex
I'm thinking it's just the idle problems some NB8A's have experienced, slight droop when coming to a stop
Lots of possible fixes out there, I haven't tried any yet because mine is quite small and not too noticeable and even then it only happens when cold and about 1 in every 10 trips
- AJ
SM wrote:I'm thinking it's just the idle problems some NB8A's have experienced, slight droop when coming to a stop
XMX5 Rogues
my car has started doing this again, i think (in my case) that the spark plugs are getting covered in oil (anyone have any ideas on that, need a new head gasket maybe?) and it they leads are getting covered, i noticed this when i changed the leads over. once changed it stopped doing this for a few days.
- Caffeine
beabea wrote:just took the car to local repco car service, found out that the water pump is leaking badly and the car got over heated. now i have to pay for a new pump and radiator. I am going to change the timing belt at the same time as its about 94,000km.
Why a new radiator? If it's just the water pump, get that done as part of the 100K service and be on your way...
