Anyone using Ethanol mix fuel
- Grumpy
I filled up the NA6 prior to a sprint at Phillip Island recently, by accident, and was a bit worried it may not work to well. Managed to get down by 2.5 seconds from my previous best on the day. Maybe it helped ???
Sadly MX5 less for a while.
Rebuilding an 89 Honda CRX
- Boags
If you weren't using ethanol blend you may have got down by 3 seconds...
COW.
COW.
- 16bit
- Matty
Re: Anyone using Ethanol mix fuel
Grumpy wrote:I filled up the NA6 prior to a sprint at Phillip Island recently, by accident, and was a bit worried it may not work to well. Managed to get down by 2.5 seconds from my previous best on the day. Maybe it helped ???
If you can't tell whether it was the car or you that accounts for 2.5 seconds, it was you.
- Grumpy
Thanks for the vote of confidence Matty.
I must admit that the brother and the nephew were also quicker on the day. Upon investigation it seems there was a race meeting the previous weekend and the track must have still had lots of rubber on it.
Best we managed for the day was 2.04.5 in an almost standard NA6 (1600), so we are pretty pleased with that.
- Grumpy
- Alf
Grumpy wrote:According to the list of vehicles I saw, MX5's from 2005 onwards are fine.
Unfortunately that leaves out NAs and NBs. I did read advice on the Mazda Australia site at one stage not to use ethanol blends greater than 5% in NB8As due to a perishing effect on some of the rubber or plastic parts. Can't comment on a '90 NA6 though.
Alf
2015 ND MT GT Crystal White Pearl Mica (pic to come)
- SuperMazdaKart
- Damo
Grumpy wrote:According to the list of vehicles I saw, MX5's from 2005 onwards are fine. I used 3/4 of the tank on the track and don't use the car as a daily anymore so can't comment further.
I would imagine that that is not because it is definitely not Ok but rather because they never tested it at the time and aren't going to spend money testing an old car now. Having said that I would rather not use it for my car to be safe and because I don't like peoples food supply going to my fuel tank.
NB8A (2000 Highlight Silver), KU36, Kaaz LSD, QFM A1RM, Mazda Competition engine/differential mounts, Town & Country cat-back.
- irwin83r
- Sean
