I just got back from out in the shed. I thought that I would check the timing, so I borrowed my mates timing light and started...
Shorted gnd and ten in the diagnostics block, on a warm engine, and checked that the idle was sitting at 800-900rpm. Trigger for the timing light was coming from the closest cylinder lead to the radiator....
I can see two timing marks on the crank pulley, one yellow and one white.
The white one is sitting at about 18 deg and the yellow (to the left of it ) is sitting off the scale at what I estimate at 24-26 deg!!!!!
I checked this twice, totally removing the timing setup between tests.
My car is not pinging (as far as I can tell) and I have not adjusted the timing since I bought it 5 months ago. It is an NA8.
It has done 4 track days since then and felt fine! I run only 98 octane BP fuel in it.
Does this sound weird to anyone else???
Should I be worried???
Chris
EDIT just went out to check it again, got the same results but noticed that the timing seems to wander a little bit, not quite a steady mark, its moving a degree or so either side of being steady.
