I Did this to the Engine
No4 The broken one also cracked the Block on both sides
O Well thats Racing
A big thanks To Turbo Girl for Letting me use her car on Sunday
Hellmun wrote:Are those the standard pistons out of an NB Russel?
Benny wrote:The standard engines do have soft rods.
They are fine for any NA engine, but if you want to run more than 5 or 6 lbs of boost (less than 0.5 atm), you'll need stronger rods.
I bet that every SP out there has at least one bent rod in the block, even if it is stock standard.
Dave wrote:Benny wrote:The standard engines do have soft rods.
I don't think so George... over 170,000k, mostly on 10+ lbs (for a short while 13
) and not an issue.
You don't tend to drive around for too long with a bent rod before something tries to escape from your block!
(probably jinxed myself now...)
