3A Racing Pod filter
zz00me
Postby zz00me » Tue Jun 10, 2008 6:14 pm
Hi Guys,
I have 1994 Na 1.8 and I am deciding wheather to put in 3a racing pod filter that I have.
Unfortunatley I know very little about them.
Car is here
http://www.aus-cartalk.com/viewtopic.php?t=30300
I have read some test results on pod filters a little while ago and this one was the clear winner.
I think that this is a dry filter, can anyone confirm?
The box says nothing.
Is it worth putting this filter on or are pod filters just a bit of bling?
I am not expecting a large performance boost.
Keep in mind that the car has stock exhaust, so is this worth it?
thanks everyone.
AB7
Postby AB7 » Tue Jun 10, 2008 6:47 pm
I had 3A pod filter before, they are oiled cotton type not dry.
Pod filter without any type of heatshield will give you less power.
stevesports
Postby stevesports » Tue Jun 10, 2008 6:53 pm
Get the urethane filters (dry type).
The one i have is a DR/FT one from autobarn.
A pod filter will generally not provide any performance gain, other than a nice sound on a stock NA engine. Generally the biggest restriction in airflow isn't the filter, but rather the design of the intake tract. If you are looking for performance gains, i would look to reducing the resistance between the intake pickup point to the throttle body.
Alex
Postby Alex » Tue Jun 10, 2008 10:44 pm
Autosalon did a test for flow and filtration, I think the 3A filter came first or second
I'm using one atm, but didn't have anything to compare to besides the stock setup
I would do it just for the sound :oops:
but you might get a bit better response as well
ducktape69
Postby ducktape69 » Wed Jun 11, 2008 12:58 pm
pros: better response...better sound...same fuel economy
cons: MUST have some sort of heatshield otherwise the engine heat really creates lagginess especially in traffic.
