hey guys
wanting to do some simple DIY mods and just after any info or instructions/ set by step/ pics on how to do a coolant re route and wiring up both radiator fans in parallel on my NB8A??
Also where did u souce the smaller sized aluminium pipng and coolant lines for the coolant re route mod??
any help would be greatly appreciated
thank u
Coolant re-route & wiring up rad fans in parallel
- travyMX5
Here is some info on the fan setup.
'99-2000 - http://www.miata.net/garage/parallel_fan.html
Early NA - http://www.miata.net/hakuna/parallel%20 ... iring.html
J
J
- SuperMazdaKart
- travyMX5
cooling
na working on better cooling.
car is pumped pretty hard and sees oil temps of 130 after 4 laps. currently have 40mm cooling pro but swapping to a 40mm pwr and also adding oil cooler. just wanna do all i can to protect it.
- sliq
JBT wrote:
People keep asking but.......here is a how to:
Posting Photos (how I do it anyway) Smile
1. Click on “post reply†or “new topic†as required.
2. Open a new browser window/tab.
3. Go to http://imageshack.us/
4. Check the “resize image?†box.
5. Click on the “browse†button.
6. Find your photo on your hard drive, click on the file name, then click on “open†at the bottom of that menu screen.
7. Click on the “host it†button.
8. Wait for Image Shack to upload your photo.
9. When the screen changes, go to the bottom URL link which is “direct link to imageâ€.
10. Click on that link and it should become highlighted.
11. Go to the top of the screen and click on “edit†and then “copy†(or go Ctrl+C).
12. Go to the window/tab with your post reply.
13. Go to “edit†then “paste†(or Ctrl+V). The URL will appear.
14. Highlight the URL and then click on the “IMG†button in the posting controls. You should see [img]at%20the%20beginning%20and[/img] at the end of the URL.
15. Preview your post and, if OK, submit it.
