bleed order
Posted: Tue Jun 03, 2008 3:25 pm
by 16bit
just wondering what the bleeding order is for an nb8a. thanks!
Posted: Tue Jun 03, 2008 3:30 pm
by JBT
Start with the longest brake line from the master cylinder and end with the shortest. Should be something like, LR, RR, LF, RF but depends how the lines were run.
Posted: Tue Jun 03, 2008 5:55 pm
by Okibi
Yup that sounds correct. I can't confirm til i'm home.
(Right hand drive)
Passenger Rear
Drivers Rear
Passenger Front
Drivers Front
Posted: Tue Jun 03, 2008 6:13 pm
by 16bit
sweet thanks!
Posted: Thu Jun 05, 2008 7:54 pm
by Woo
Swap the Left and Rights in the above descriptions accounting for ABS on the '00 (four wheel ABS)
Swap the Front Left and Front Right on the '99 with ABS (3 wheel ABS)
Edit* The key is as JBT says start with the longest line (from the ABS pump or Master cylinder)
