torson diff...second hand or new
mhj
Vehicle: NB8A - Supercharged
Postby mhj » Thu May 22, 2008 12:48 pm
hello
i am going to add a torson diff to the nba.... as mixxy becomes a sicker little rabbit week by week
....new ones at the mania are $1500, old ones are obviously less
are there any potential wearing out issues with second hand torsion diffs?
also what is the best ratio..problems /advantages.?..i gather the standard is 4.1...3.9 makes you accelarate faster....4.3 makes it longer legged...but the speedo reads low
enjoy
mhj
mhj
Boags
Postby Boags » Thu May 22, 2008 12:54 pm
Hi Mate,
MX5Plus have a few different ratios to choose from if you go the second hand route. You could get it shipped in the same pallet as the roll hoops.
Justa thought.
Boags
16bit
Postby 16bit » Thu May 22, 2008 1:20 pm
other way around mate - the lower the end ratio the longer the gearing. I would stick with 4.1 unless you are going to have over 300hp at which point you would probably need longer gearing to make use of the torque. For the money you are looking at I would get a kaaz 1.5 clutch type. they are 750 new from japan and are a better option to the torsen from what I can tell.
16bit
Postby 16bit » Thu May 22, 2008 1:23 pm
http://www.nengun.com/kaaz/lsd
its closer to 700 with the better exchange rate
Damo
Postby Damo » Thu May 22, 2008 4:08 pm
Anyone know the relative costs of installing the clutch type to a Torsen (particularly if you know any places in Melbourne?) I'm considering the KAAZ at the moment seeing as the new cost is similar to a second hand Torsen.
16bit
Postby 16bit » Thu May 22, 2008 4:53 pm
not sure in melbourne but i have been quoted 300 to install it in brisbane. it will cost about 950 delivered so about 1250 installed which is cheaper then just the torsen its self.
Postby Okibi » Thu May 22, 2008 4:58 pm
Also worth checking if they are mazda torsens or remakes like OBX?
Alex
Postby Alex » Thu May 22, 2008 5:58 pm
never heard of any wear issues with the Torsen, unless like fuzzlet you decide to run 200kw through it on a drag stip
Damo
Postby Damo » Thu May 22, 2008 9:55 pm
16bit wrote:not sure in melbourne but i have been quoted 300 to install it in brisbane. it will cost about 950 delivered so about 1250 installed which is cheaper then just the torsen its self.
Thanks 16bit. Yeah that price seems tolerable. I called a wrecker and was quoted $850 for the second-hand Torsens when they had them, but they didn't have any at the time. So if I'm going to pay in that ballpark then I may as well have something designed for racing.
Do the people doing the swap need to really know what they are doing (ie. can someone do a good job/bad job or once it's in will it be ok?)
StanTheMan
Postby StanTheMan » Thu May 22, 2008 10:17 pm
marrying the crown to the Pin & diff is the tricky bit. it has to be pretty exact.
Once someone has been shown how to do it properly, its probably a walk in the park. But its probably best left to the professionals. As I certainly wouln't like to have my diff as a gunea pig.
You could probably take the parts to the pros. get them to put the crown wheel on & then install the diff yourself. If you are that way inclined. But I think $300 is about the going price for installation of the diff & changing over the crown wheel.
Noodle
Postby Noodle » Wed Feb 11, 2009 8:28 pm
Hm... didn't see anyone answer this question. I'm curious of the answer too.
StanTheMan
Postby StanTheMan » Wed Feb 11, 2009 9:38 pm
anything that moves, wears out or has the potential to wear out.
Like someone said if you put 200rwkw down on the drag strip......it has the potential to break. Your standard or slightly modded NA/B it should last a very long time without needing maintenance.
Matty
Postby Matty » Thu Feb 12, 2009 1:32 pm
Yeah, but the wear rate of intermeshing gears is significantly less than that of say clutch plates rubbing against each other.
16bit
Postby 16bit » Thu Feb 12, 2009 2:03 pm
what he said^^. clutch types need to be serviced and rebuilt. torsens should last a very very long time if they are looked after and not over powered. massive hp and drag strip launches will break them quicker.
daffyflyer
Postby daffyflyer » Thu Feb 12, 2009 2:38 pm
mhj wrote:i gather the standard is 4.1...3.9 makes you accelarate faster....4.3 makes it longer legged
Opposite I should say, 4.3 is lower gearing = more revs = more acceleration = less top speed, yes?
Developing a Car Industry Game - Visit www.automationgame.com
White 1994 MX5 Clubman - Carco Built NA Motor - 101kw ATW @ 7500rpm
