Castrol Edge?
Posted: Wed May 21, 2008 10:51 pm
by TieNN89
Hi There,
I remembered someone on here said Supercheap was selling Castrol Edge cheap
well I went into SCA today and saw Castrol Edge 5 - 30 for just under 30 save 29 something
Anyway a question to those who are using it is it worth the extra $$ on top of Castrol Magnatec (stuff I'm running atm)? at normal prices that is
I'm running 10w-40 atm is it ok to run 5w - 30 in my nb
Re: Castrol Edge?
Posted: Thu May 22, 2008 9:17 am
by Steampunk
AZNTieN wrote:Hi There,
T'was me! :P
A lower viscosity is always better in colder climates, so go for it.
It's really a matter of personal opinion as to which is better lubricant.
Posted: Thu May 22, 2008 10:54 am
by stevesports
ahhh, i would go with the mazda recommendations. Lower viscosity, and correct me if im wrong means thinner oil of what's required, which means higher friction between metal. This could mean higher wear on the parts.
Posted: Thu May 22, 2008 11:04 am
by wun911
I look at my past service reciepts from Mazda and they keep chaning the viscosity, from 10w30 in one servce to 10w40 in another service etc etc.
Posted: Thu May 22, 2008 1:27 pm
by Blue94t
Wun,
Ask them to stick with the 10w30, it weighs less :lol:
jake
Posted: Thu May 22, 2008 2:10 pm
by Steampunk
5w-30 weighs even less Jake :wink:
Re: Castrol Edge?
Posted: Sat Jan 30, 2016 9:47 pm
by rattyntoad
Castrol Edge 5 - 30 for $29 at Repco this weekend only.
Re: Castrol Edge?
Posted: Sun Jan 31, 2016 8:58 am
by RS2000
Edge is fully synthetic, so better than semi-synthetic Magnatec
Don't know what NB you have, but Castrol actually recommend 5W-30 with both oils for NB8B (also recommend 0W-40 Edge)
http://www.datateck.com.au/lube/castr_au/default.asp
Re: Castrol Edge?
Posted: Sun Jan 31, 2016 10:54 am
by manga_blue
I used Edge 5W30 for years, including a lot of track work. It's fine and it's a helluva lot better than the retail version of Magnatec which is a cheap dyno oil wrapped in heavy marketing. There is a full synthetic Magnatec available to Subaru dealerships called Magnatec Professional - it's alright if you can find it.
