Page 1 of 2
Whining Noise on start-up
Posted: Fri May 16, 2008 1:48 am
by RaYmO
Hi Guys,
Just noticed today that when I start the engine when cold, there is a distinct whining noise that lasts for about 10 seconds before it goes away completely (and no it's not coming from the passenger)...
Anyone experienced something like this before?
Posted: Fri May 16, 2008 1:56 am
by SuperMazdaKart
maybe it's the driver?
or a belt?
Posted: Sat May 17, 2008 1:59 pm
by RaYmO
The sound is still there but rather than going for 10 sec, it's only going for 5 now...
Maybe itll be gone in a few days LOL
Posted: Sat May 17, 2008 7:50 pm
by marcusus
Maybe it's the supercharger you've never noticed in the engine bay
Posted: Sat May 17, 2008 8:33 pm
by JBT
Looks like sensible answers are not on the menu.
Check belts - try a bit of soap on them to see if that cures it. If not it could be, PS pump (if fitted), AC compressor (if fitted), alternator, water pump or cam belt tensioner.
Posted: Sat May 17, 2008 11:15 pm
by Spranga
Assuming no one has secretly installed a supercharger my money is on imminent water pump failure
Posted: Sat May 17, 2008 11:36 pm
by StanTheMan
Both my waterpumps made a metalick sounding noise .....for about 12mths before they failed. It was more a sort of a constant noise but it would be there always.....not dissapaer.... until the waterpump got replaced
I'd ceratinly be checking in JBT's & sprangas direction.
Posted: Mon May 19, 2008 10:13 am
by RaYmO
Thanks for your input guys
I'll give the belts a run through tonight
The weird thing is that this noise is only present on cold startup - When I restart the car when the engine is warm there is no noise
Also, if it were the belts... wouldn't the noise be constant (ie not go away after 10 or so seconds?)
I think the culprit may be the AC condenser as that has always been noisy since the last regassing.
Posted: Mon May 19, 2008 11:10 am
by JBT
RaYmO wrote:Also, if it were the belts... wouldn't the noise be constant (ie not go away after 10 or so seconds?)
Not always, that's why it was suggested as a possible cause.
Posted: Mon May 19, 2008 1:57 pm
by bruce
The belts on the Suzuki shriek on a cold start. Warm, they're fine. Put a bit of soap on them and it helped (only shrieks occasionally).
Posted: Tue May 20, 2008 10:04 pm
by RaYmO
OK
Managed to do a quick check this morning.
I put the key in the ignition and turned it so the radio was on (without starting the engine)
The noise was LOUD as I had my bonnet up. Was following the noise and it is coming from the Fan in the Radiator. It sounds like the fan is rubbing against the metal...
Is it possible that the fan is somehow loose and needs to be tightened up?
Posted: Tue May 20, 2008 10:24 pm
by Juffa
RaYmO wrote:OK
Was the engine still cold at this time? The fan should not spin unless triggered when the coolant temp reaches a certain level. Check that the shroud around the fan is not warped/bent. With the key removed check the fan for excessive movement. Obviously spinning is fine, but it should not have too much wobble.
J
Posted: Fri May 23, 2008 12:49 am
by RaYmO
Thanks Juffa
If there is a wobble, is it easy to tighten the fan blades?
Posted: Fri May 23, 2008 8:33 am
by StanTheMan
if the fan is loose thyey are easy to tighten up
there is 4 bolts at the front. You wil need a 10mm spanner. ring spanner preferred. schouln't be too difficult to reach them.
should be a walk in the park
Posted: Fri May 23, 2008 9:44 am
by RaYmO
Thanks STM
I'll have a crack at it this weekend
