Anyone one knows ?? Ticking noise from the clutch !!!
Posted: Fri May 09, 2008 11:35 am
by maxmx5
Hi Guys,
I got a high pitch ticking noise from the clutch, it happens when the car is on idle, and as soon as you tap the clutch the noise goes away, all it need is a very gentle tap or put your foot on the clutch and the noise goes away !!
any one who has this issue in the past please advise ..
thank you very much
Posted: Fri May 09, 2008 11:53 am
by Mr Morlock
Probably thrust race- take it to clutch specialist for diagnosis.
Posted: Fri May 09, 2008 12:00 pm
by maxmx5
Mr Morlock wrote:Probably thrust race- take it to clutch specialist for diagnosis.
I spoke to a mechanic and he said that he need to pull the clutch apart and have a look.,... dam..
Posted: Fri May 09, 2008 12:15 pm
by JBT
Check that there is a small amount of grease on the end of the slave cylinder plunger where it contacts the clutch release lever.
Posted: Fri May 09, 2008 12:23 pm
by Garry
What JBT said. Much cheaper than a clutch overhaul.
Posted: Fri May 09, 2008 12:35 pm
by silvermiata
JBT
Posted: Thu May 08, 2008 1:15 pm Post subject:
x 2
Ticking noise,
Posted: Fri May 09, 2008 12:37 pm
by maxmx5
I am going to give it a try to see how it goes, thanks a lot guys...
