Another diff type oil question (newbie)
Posted: Fri Apr 25, 2008 7:19 pm
I’m totally new to “forums†and fairly new to my ‘5 (MAX, a 01 NB8B), but have found the search keeps taking me to here and the US one. What an eye-opener and source of real practical knowledge (with pictures no less). Thanks to all of you for the vast amount of accumulated wisdom and “how to’s †I’ve used from this forum.
The humour is (mostly) great to boot!
I have changed all of the fluids in Max to establish a known base line. (Thanks for the MT-90 tip especially).
My question is about the amount of fluid in the Diff. The Handbook says 1 Litre or 1.1 US qt. Armed with two Redline 75W90 1 US qt containers and the wonderful tube / funnel tip the job was started. The diff was drained totally, left open for over two hours while I did something else. No drips coming out at all when I got back to it. My tube and funnel arrangement consists of a large funnel (holds maybe a litre and a half ) and the tube has a in-line tap just before the end so I can control the flow while under the car. Put the whole Redline container (1 US qt) into the Funnel and got under the car and let her rip. I expected the whole first lot to go in, but it overflowed the filler at about .8 of a litre. Yes, the tube was in correctly (deepish and angled down).
No biggy, I guess, if its full its full, and I have bonus “spare†bottle for next time. But after reading an old Topic started by Spitty about diff types (what a discussion) and a more recent one started by Stevesports about “gearbox and differential oilâ€
I noted that zoomzoom stated “EPX 80W-90 for the diff, about 900mL-1L for torsen and I thnk around double that for an open diff†and “Open diff will likely take more than 1L from memory.â€
Is this correct?
Is there a difference in the capacity between the open diff and the torsen?
The Spitty topic offered three options to check the diff type, pull the thing apart and look, jack-it-up and spin the wheels and lastly lay some rubber (on grass).
The last two options were shot down as being inconclusive.
Does anyone that knows they have a Torsen know what amount of oil they can get in?
Same question for anyone that knows they have a open std diff.
Thanks, Steve
Is this correct?
Thanks, Steve
