Advance Timing on a NB, anyone done it?
satanoperca
Postby satanoperca » Thu Apr 10, 2008 1:09 pm
Hi,
Has anyone advance the timing on a NB by modifying the CAS bracket?
My current static timing is 8 TDC and would like to advance it to 12 TDC. I run 98Ron fuel.
Did you move the bracket up?
Did it achieve any noticable differences in power?
Benjamin
Rotary
Postby Rotary » Sat Apr 12, 2008 12:27 am
Yeah, its one of the best mods i have done so far.
Good improvement in low down midrange torque
Massive improvement to overall drivability, light throttle, take off etc.
Very easy to do, I did it similar to the above instructions(drill hole in sensor). but using calculations i worked it out to be +8 degrees advanced.
this advance runs perfect even on 91 ULP. so i might advance some more
ducktape69
Postby ducktape69 » Sat Apr 12, 2008 3:07 pm
seems pretty silly to me...
mazda spent a lot of time and money to UPGRADE the engine to vti.
why would you go backwards?
satanoperca
thanks for the replies
Postby satanoperca » Mon Apr 14, 2008 5:19 pm
Thanks for the replies.
I have gleamed much information form the miata.net site.
I do not believe my 98 model came with VVT or VTI.
I will give this mod a go and report back.
Benjamin
SuperMazdaKart
Postby SuperMazdaKart » Mon Apr 14, 2008 5:42 pm
it's SV-T isn't it?
Fra66L
Postby Fra66L » Mon Apr 14, 2008 9:09 pm
Yep! :D
The Green Meanie - Grace Green NB8A
Veilside - It's Japanese for UGRY!
samx5
Postby samx5 » Tue Apr 06, 2010 4:38 pm
Just been looking at this for an NB8A (no VVT of course), I've been informed that you can get a part off the shelf that gives an advance to 14 deg - I'm no mechanic but I believe its the black disc that spins inside the CAS that is replaced with an aftermarket part to change the ignition to 14 BTDC......? Has anyone done this mod? It doesn't seem to need the dremel like the method described earlier in this thread & seems to be easily reversible......?
Was: 1988 Corolla 4A-GE Twin Cam, 1991 Laser TX3, 1995 Peugeot 306 S16, 2003 Astra Sri Turbo, 2007 SP23 Lux
Now:1999 NB8A, 2011 Outlander VR-X
wun911
Postby wun911 » Tue Apr 06, 2010 5:45 pm
Would this be the same effect as buying and installing adjustable cam gears???
I have the VVT I hear some pplz on turbo miata net disabling it when they install their turbos, apparently when disabled its effectively increasing the intake timming???
every ounce counts
