removing the aircon - NA6
Fatty
Postby Fatty » Tue Apr 01, 2008 10:36 am
hey guys,
i will getting the system de-gassed today and then removing it at some point.
i know a few others have done this , are there any hints or tips you can share? how do i get at the condenser in the front... do i need to take the radiator out? take the nose off ? any tips or help appreciated .
cheers
james
jerrah
Postby jerrah » Tue Apr 01, 2008 11:40 am
As the aircon in my MX5 doesn't work either I'll probably do this myself at some point.
1991 MX5
kula
Postby kula » Tue Apr 01, 2008 12:18 pm
i did mine a while back,
very easy,
radiator doesnt have to come out.
just unbolt it all and away you go.
randymx5
Postby randymx5 » Tue Apr 01, 2008 4:03 pm
What have/are you guys doing with your air cons once removed?
Im after the 'u' shaped piping which goes fromm front of the radiator to behind it... any chance someone wants to sell me theirs?
I have a holein mine from where it rubbed against some other plumming (turbo)
R&ALL
RED 1990 MX5, AVO stage II, 148.5rwKw
Fatty
Postby Fatty » Tue Apr 01, 2008 4:25 pm
well i'm planning to keep mine just in case i decide to refit it later. if i was to sell anything i would only sell it as a complete set. it doesn't make sense to part it out as that would devalue all the left over parts.
surely you can get a peice of pipe made up at an aircon specialist, or buy it from mazda / wreckers?
wun911
Postby wun911 » Tue Apr 01, 2008 7:41 pm
I want to see and learn....
every ounce counts
Fatty
Postby Fatty » Tue Apr 01, 2008 7:46 pm
come over in the morning mate. say about 9.30 ?
wun911
Postby wun911 » Tue Apr 01, 2008 7:52 pm
sigh cant make it no wheels... LOL
Take some pics for if you can...
every ounce counts
Fatty
Postby Fatty » Tue Apr 01, 2008 7:53 pm
oh yeah... i forgot about that . bugger.
i'll try to find the camera and take some pics.
ampz
Postby ampz » Tue Apr 01, 2008 8:44 pm
Hey Fatty,
When you remove the compresor bracket that bolts to the side of the block, it has a bolt going through the front of the engine too. This bolt also hold your oil pump and it will be too long once you remove the aircon bracket.
If you leave the bolt off, your pump will eventually leak all over the place (how do i know this? :oops: ) Find yourself the same bolt (12mm head from memory, but I've had 3 beers) about 15mm shorter and you should be sweet! :mrgreen:
Huh?
Fatty
Postby Fatty » Wed Apr 02, 2008 9:23 am
thanks ampz, that's exactly the sort of info i was after.
sabretooth
Postby sabretooth » Thu Apr 03, 2008 2:40 pm
How do you people live without your AC?? :shock:
kula
Postby kula » Thu Apr 03, 2008 3:11 pm
yeah summer is a little tough...
but this weather now is perfect..
22-23 degrees is ideal:)
Fatty
Postby Fatty » Thu Apr 03, 2008 4:51 pm
well it;s been inoperative for a while now ive just learnt to live without it. it was difficult at first but you get used to it. my car is not really a daily driver anymore so it's not too bad. if it was a daily driver i' think twice about removing it , and maybe take the time to get it operational again.
Fatty
Postby Fatty » Thu Apr 03, 2008 5:37 pm
rain delay
