Çoolant hoses ...
SuperMazdaKart
Postby SuperMazdaKart » Mon Mar 31, 2008 12:44 pm
perhaps consider getting the silicone hoses set from mx5parts.co.uk & be done with it for a long time :)
Steampunk
Postby Steampunk » Mon Mar 31, 2008 7:57 pm
x2
Silicone hoses are expensive (but probably the same $ as genuine OEM rubber ones), but the value is that they will last indefinitely.
GP
Postby GP » Tue Apr 01, 2008 10:48 am
You sure that's not just hype?, Can't Imagine Silicon lasting much longer
Graham
Juffa
Postby Juffa » Tue Apr 01, 2008 12:26 pm
The rubber ones will be fine. You will probably find that you will also need to replace the retaining clamps. They never seem to hold/seal as well when re-used. I have just tended to use the worm drive type hose clamp. And you are right about the cost.....expect to pay around $300+ to replace the lot....and thats just for the hoses.
J
Postby bruce » Tue Apr 01, 2008 5:10 pm
You could buy black garden variety silicon ones (instead of flashy red, blue, yellow).
