Hey guys,
Had a compression test today as Lara is starting to blow a bit of blue smoke.
Just wondering what the stock compression rates are.
Lara went
1. 162 psi
2. 157 psi
3. 161 psi
4. 163 psi
I'm thinking a 6 psi spread over the 4 cyclinders isn't bad, but if all four have dropped pressure, then maybe it is time for the engine overhaul.
Matt
Stock compression pressure for a NA8?
- Li7hium
NA8
Wakefield 1:14:78 28-6-09! Oran Park GP 1:27:73 30-03-08 Oran Park South 54:50 14-10-2007 Eastern Creek 2:02:44 6-8-07
BRZ
Pheasant Wood 1:05.4940
BRZ
- godfather of saké
- ampz
- Vehicle: NA6 - Turbo
- Li7hium
Thanks for the info guys.
I shouldn't be surprised since it is not dríven by a Granny only taking it to Church on Sundays.
Mechanics have indicated that another guage of oil isn't required at this stage as the sparks plugs are clean with no indication that it is burning oil (aside from the aforementioned blue smoke).
I'll keep an eye on it this weekend when Dad is driving it around Oran Park.
Still, I am going to be obtaining some quotes to have an engine rebuilt and keep running this one this year.
Matt
Matt
NA8
BRZ
BRZ
Li7hium wrote:Mechanics have indicated that another guage of oil isn't required at this stage ...
I meant another compression gauge. I wouldn't trust just one set of readings.
