whirring noise in gearbox
stevesports
Postby stevesports » Thu Mar 13, 2008 11:20 pm
Any NB8B guys, can you try something for me?
can you find a quiet sort of place, go up to like 50-60km/h, get out of gear and into neutral, release and clutch and try to engage first gear. Now don't exactly try to get into gear, but apply a little force so the synchro is engaged. Tell me do you hear a whirring sort of sound, kind of like 2 straight cut gears are moving together?
i mean is this normal? are the synchros supposed to make that noise?
Alex
Postby Alex » Fri Mar 14, 2008 1:46 am
I must say trying to push into 1st while going at 50-60km/h doesn't sound like my gearbox's idea of fun
if it only happens under the conditions that you mentioned then I wouldn't be worried
if not then post up what you are actually doing when you hear this sound
stevesports
Postby stevesports » Fri Mar 14, 2008 7:47 am
sorry i don't mean actually engage first gear, but place a little pressure on it such that the synchros spin up.
i also hear this sound when i'm in first gear and i'm accelerating. This also occurs but to a lesser extent in 2nd and to an even lesser extent in 3rd.
JBT
Postby JBT » Fri Mar 14, 2008 8:22 am
Normal.
wun911
Postby wun911 » Fri Mar 14, 2008 8:48 am
normal mechanical noize?
every ounce counts
Postby bruce » Fri Mar 14, 2008 10:23 am
Sounds normal to me.
Stupid thing to be doing to the poor box.
silvermiata
Postby silvermiata » Fri Mar 14, 2008 10:32 am
erven if anything is starting to go wrong with the box, you dont need to worry for a long while :)
is it a whining noise like a supercharger or whirring?
Uncle Arthur
Dodgy Award Benefactor
Re: whirring noise in gearbox
Postby Uncle Arthur » Fri Mar 14, 2008 12:36 pm
stevesports wrote:Any NB8B guys, can you try something for me?
Sounds like you need a new hamster.
stevesports
Postby stevesports » Sat Mar 15, 2008 5:18 pm
whining noise sorry. Kind of like a supercharger i guess. I can tell it is the synchro spinning up.
JBT
Postby JBT » Sat Mar 15, 2008 5:22 pm
The gearbox is trying to tell you \"don't do this to me!\"
stevesports
Postby stevesports » Sat Mar 15, 2008 7:29 pm
Let me explain it this way, there is a whining noise when i am in first gear and accelerating. It is less prominate as i move up the gears. Faint in 2nd gear, even less audible in 3rd and inaudible in 4th. In addition, the sound decreases as the gearbox warms up.
the reason i explained the above situation is to isolate the problem. As i said, i've narrowed the noise down to synchros (which i think is correct).
JBT
Postby JBT » Sat Mar 15, 2008 7:35 pm
You would have to ride in/drive another similar model MX-5 under the same conditions to see if what you're experiencing is normal or not.
It's impossible to draw worthwhile conclusions on a chat board.
silvermiata
Postby silvermiata » Sun Mar 16, 2008 11:02 am
i had the same problem/ have the same problem... its a bering failure in the gearbox (i think countershaft bearing)... i had the same small noise about a year ago.. and now its quite audible...
typical problem with mexy gboxes... you can find topics with the same problems in miata.net forums....
bensale
Postby bensale » Sun Mar 16, 2008 11:20 am
One thing that can contribute to gearbox noise in the mx5 is the proximity of the gearbox to yourself.
I know my NA6 has a bit of gearbox noise, as does ever one i've been in so I would say its typical. I've never been in a nb so I cant on them.
I would recomend a back to back test, maybe take a mate down to a car yard with a nb and go for a test drive.
www.othersideproductions.com
wun911
Postby wun911 » Sun Mar 16, 2008 9:38 pm
Dont worry bro your goin to change the fluids on dodgy day :D
So we will get to see all the chunks of metal stuck the the magnetic plug from all that whirling noise in the gear box :)
every ounce counts
