Page 1 of 2
Differential pinion gear and crown go crunch
Posted: Sat Mar 08, 2008 11:17 pm
by Uncle Arthur
Goes crunch.
Car no go.
Posted: Sat Mar 08, 2008 11:43 pm
by sabretooth
Ouch.
Time for a new driveshaft?
Posted: Sun Mar 09, 2008 6:40 am
by JBT
Sorry I could not mount a rescue UA.......too much wine/beer/BBQ which was still in progress. I reckon my BAL was probably about 0.15
Breathe easy if it's just a driveshaft CV joint.......much better than a dead diff.
Posted: Sun Mar 09, 2008 9:56 am
by manga_blue
Congratulations. It takes good power to do that.
Posted: Sun Mar 09, 2008 10:01 am
by Boyracer
Time for 1.8 diff conversion...
Posted: Sun Mar 09, 2008 12:02 pm
by Uncle Arthur
JBT wrote:Sorry I could not mount a rescue UA.......too much wine/beer/BBQ which was still in progress. I reckon my BAL was probably about 0.15
No probs JBT
- and it looks like a driveshaft CV joint (well - sounded like it)
Posted: Sun Mar 09, 2008 12:05 pm
by Boags
Uncle Arthur wrote:JBT wrote:Sorry I could not mount a rescue UA.......too much wine/beer/BBQ which was still in progress. I reckon my BAL was probably about 0.15
No probs JBT
You have been a naughty boy!
Don't be too surprised if it's the diff though.
Posted: Sun Mar 09, 2008 1:14 pm
by StanTheMan
are you still running a 1.6 diff
and if it turns out to be the CV joint
Thats not the way its supposed to work
Re: Blew a rear uni joint
Posted: Sun Mar 09, 2008 1:24 pm
by Boags
Uncle Arthur wrote:Goes crunch.
Car no go.
So you put it in gear and let out the clutch and wheels don't turn? Unless the drive shaft actually fell out; I think it's diff.
Fecked universals vibrate badly, they don't stop you from going (AFAIK - please correct me if I'm talking sh!t).
Boags
Posted: Sun Mar 09, 2008 5:43 pm
by manga_blue
Non-LSD diff driving a broken halfshaft would mean you don't go anywhere. All power would go to the broken side which would just turn and grind away.
In any case it's easy enough to check. Just get someone to look at the half-shafts while you try to move off.
Posted: Sun Mar 09, 2008 6:50 pm
by StanTheMan
If you've broken a CV joint. Wouldn't it stick out like dogs balls?
You'd have bits of bearing flying everywhere .
My diff made all sorts of grinding noises when it had gone pear shape. but in my case the dead give away was the fact that the dif case was split & the oils was leaking & left a nice tell tale to where i'd rolled to to stop.
Anyway I hope its not the diff......another pretty expensive excersise....but then. mmmmm....more upgrades for UA.
Posted: Sun Mar 09, 2008 8:43 pm
by Uncle Arthur
Weeeeellllllllll..
It ain't the uni joint. Pinion gear has shattered. Chipped a few teeth on the crown to boot. Mazdaspeed centre is still good.
Will be looking to put the lot up for sale to interested buyers to explore the torsen option. I bought this complete from Cal a while back, had it rebuilt, so I can tell you how much you should expect to pay to have this rebuilt. I needed a new pinion. You are obviously going to need new crown and pinion. I would suggest a full rebuild because of possibility of metal shavings, but the centre is intact - I'll strip it to be sure.
It has held up to well over 110 RWKW for a while now, so would be great for a NA version with a bit of grunt - just don't use the mazda pinion gear - get an aftermarket made up. If you are interested, let me know.
Here's a pic........
Posted: Sun Mar 09, 2008 9:48 pm
by JBT
Baaaargar
. MX-5 Plus had a fair stock of TorSens a while back.
Posted: Sun Mar 09, 2008 10:10 pm
by MxJadeMonkey
How much for the Mazdaspeed centre please?
Posted: Mon Mar 10, 2008 8:08 am
by corners
Hmm I have done that before.
The inside of your diff doesnt look very clean
