input shaft bearing
Posted: Mon Mar 03, 2008 10:46 am
by silvermiata
hi guys,
i have the whiny gearbox (whines in 1,2,3 and5 th) and i have been thinking about taking the tranny out to change my clutch and possible change the input shaft bearing as well as seals.
My question is, is it possible to take this bearing out without taking the tranny apart?
Has anyone done this? if yes, could you give us some advice.
Thanks.
Jahn
Posted: Mon Mar 03, 2008 8:01 pm
by Russellb
You are going to have to Strip strip the box compleatly .
the noise is proberly coming from the front Layshaft Bearing and not the
input shaft bearing. the Layshaft only comes into play in 1,2,3,5th gear
in 4Th gear the Input and Output shafts are conected together, so no load goes throught the layshaft . either way the box need to be striped.
Re: input shaft bearing
Posted: Tue Mar 04, 2008 2:19 pm
by hot rod
silvermiata wrote:hi guys,
Thanks.
Jahn
As long as it shifts ok, you're wasting your time. Can't expect to own a performance car without a few noises! Mine wines in 2nd and 3rd too.
Posted: Thu Mar 06, 2008 1:48 pm
by silvermiata
well my gerbox whines big time... the noise has got louder in last couple of months, and in first and second gear it sounds exactly like a superharger whine which is cool but worrying
Also, it feels like there is a bit of a slack in the driveline which i am relating to the same problem problem.. has anyone experienced this? if anyones got it fixed in sydney how much would i be looking at if i take the gerbox out and take it to reconditioning person:)?
thanks for the advice guys...
Posted: Thu Mar 06, 2008 2:58 pm
by CT
A rebuilt one could cost anywhere from $1k up - most guys won't give you quotes until they open the box. I just had my SE box rebuilt in wollongong so pm me for their details if you are interested.
Posted: Thu Mar 06, 2008 3:44 pm
by GP
If your gearbox is noisy the important thing is get it fixed as soon as possible. The more you drive it the more it will cost to fix.
Posted: Thu Mar 06, 2008 4:23 pm
by silvermiata
CT
Posted: Wed Mar 05, 2008 3:58 pm Post subject:
i dont think think it is worthed to get it rebuilt as i can get a 6 speed for around that much..(1k -1.5 k)
I have no problems with the box, its working great but it is just noisy so i am thinking it is just a bering problem. i don't think i need a full rebuilt..
Posted: Thu Mar 06, 2008 4:40 pm
by GP
But the noise is grinding metal which is mixing with the oil and going through the entire gearbox.
Get the 6 speed
