SP Turbo type ... and problems
Craig
Postby Craig » Sat Feb 23, 2008 7:47 pm
*PAGING GARRY*
(Don't ask Casey...SP's never break down!)
:lol: :P :lol:
blackster
Postby blackster » Sat Feb 23, 2008 9:40 pm
Craig wrote:*PAGING GARRY*
:lol: :P :lol:
Play nice and help the guy out? :roll:
I believe its a Hybrid Garret based on GT25/28 design, some one correct me if I am wrong?
Cost of rebuilding is dependent on what they find, eg compressor wheel, turbine clip and whether machining and balancing is required. Yet to see a turbo rebuild less then $1k. You should be able to source a new GT25 not far from that rebuild price.
Previous
04' MX5 SE.
02' MX5 Classic ed.
Craig
Postby Craig » Sat Feb 23, 2008 9:56 pm
In a roundabout way I was...Garry replaced his on his SP, and chill out I sold my old car to this guys Brother...
blackster
Postby blackster » Sat Feb 23, 2008 10:03 pm
Craig wrote:In a roundabout way I was...Garry replaced his on his SP, and chill out I sold my old car to this guys Brother
Im perfectly chilled like the corona next to the keyboard. 8)
As for the SP/SE bashing *yawn*
Previous
04' MX5 SE.
02' MX5 Classic ed.
Postby Hammer » Sun Feb 24, 2008 4:02 pm
blackster wrote:I believe its a Hybrid Garret based on GT25/28 design, some one correct me if I am wrong?
You're right, it's a Garret T28 Shell with a T25 internals.
I've already had the turbo on my SP replaced once under warranty.
Garry
Postby Garry » Sun Feb 24, 2008 8:51 pm
Casey
Postby Casey » Sun Feb 24, 2008 9:16 pm
PM RussellB or Pilsner or give them a call at Carco Automotive - 02 6253 1396 or Carco Automotive. They have built a couple of very quick SP replica track dogs that have the SP spec turbo fitted. They have the correct Garrett part numbers.
Craig - this ones for you *phfffffttt* :mrgreen:
White SP Image
MxJadeMonkey
Postby MxJadeMonkey » Mon Feb 25, 2008 2:31 am
They run a GT2560r ball bearing turbo, i thought.
with is a gt28 housing with 25 internals, using a .60 rear housing??? anyone?
1991 NA6 Velocity Blue (Ford Colour)
Fatty
Postby Fatty » Mon Feb 25, 2008 6:21 pm
i have a gt25 of some description on my '89. i didn't use a restrictor.
NMX516
Re: SP Turbo type ... and problems
Postby NMX516 » Mon Feb 25, 2008 6:53 pm
Caedrus wrote:The vibration starts at about 2300 RPM, and stops vibrating at about 3200 RPM. I am assuming that there has been some damage to the turbo. There is a definite lack of blow off valve pressure, and the car is just feeling a little gutless (if you can say that about an SP).
You could certainly easily check for any shaft play yourself. Remove the intake piping so that you can see the compressor wheel, grab a hold of the centre bolt holding the wheel on, and see if you can move it up and down or in and out. Also, check that is spins freely without binding at all. If it is out of whack by a long way, you will hear loud metal on metal scraping noises - very not good.
As for costs of a rebuild, it will depend how much work is required. I would strongly recommend MTQ for a rebuild. They will quote for the work too, but of course need to pull the whole thing apart to be able to do that accurately. I had a T25G rebuilt by them a couple of years ago and from memory it cost around $700. They did a very good job, and give a 12month warranty on their work.
Even give MTQ a call and run the scenario by them. They were very helpful to me over the phone before I went and spent any money there.
Russellb
RIP Nov 2014
Postby Russellb » Mon Feb 25, 2008 10:11 pm
silverback2002 wrote:Do you know if they install the oil restrictor in the oil feed line.
I was told not to put it in with my NA 94. I have a GT2560R
Flyin miata in the USA said they dont use them because the MX doesnt produce much oil pressure.
Should I remove the restrictor from the feed line?????
no oil restrictor is needed on the MX5 as the Engine has one between the block and the head. the turbo for the SP is a GT2560R . replacement cost NEW is around the $1300mark with 12 moths Warranty.
My ClubmanRebuild
MX5 SE Rally car is HERE :)
Benny
Postby Benny » Tue Feb 26, 2008 2:12 pm
Russellb wrote: Replacement cost NEW is around the $1300mark with 12 moths Warranty.
And what are the 12 moths supposed to do?
Russellb
RIP Nov 2014
Postby Russellb » Tue Feb 26, 2008 8:28 pm
TYPO it was late and I had a few Beers :)
My ClubmanRebuild
